program new remote of arrow 5.1
jessgab
Posted: April 27, 2010 at 4:35 PM / IP Logged
I accidentally cleared the remotes on on my Arrow 5.1. I was trying to play with the auto start programing on the first column but skipped to the third, thus erasing both my remotes.
I tried re-programing the remotes but no luck. Do I have to get new remotes. I tried entering the Auto learn feature and pressed the lock/unlock button and it chirped once, it should have worked.
I also tried the custom configuration and again pressed the lock/unlock button and it chirped once but does not work. The * button is the only button that works which is the auto start.
Posted: April 27, 2010 at 5:10 PM / IP Logged
On master arm or custom configuration, press the lock button a second time, then it's stored.
On custom configuration, you needn't do it a second time on the other buttons.
jessgab
Posted: April 27, 2010 at 6:00 PM / IP Logged
On my smart windows, it says to press the lock/unlock+the trunk button to activate the vent feature but this does not work, this combanation disables the sensor. Do I have to set my remotes manuelly in custom configuation.
Posted: April 28, 2010 at 2:23 AM / IP Logged
Yes, unfortunately the Arrow was never designed to run lots of accessories.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
