96 blazer light problem
lynnboy021
Copper - Posts: 66
Posted: May 03, 2010 at 7:39 PM / IP Logged
ok i installed a new battery and when i close the boors or open the lift gate glass or start the car, all the light start flashing. i thougt i had an alerm system but i looked it up and the truck does not have any kind of alerm system.
Mark Mizenko
Copper - Posts: 460
Posted: May 03, 2010 at 9:05 PM / IP Logged
Look under the drivers side of the dash.  There must be some type of aftermarket system installed.  Maybe you can find the override switch or pushbutton.
lynnboy021
Copper - Posts: 66
Posted: May 03, 2010 at 11:28 PM / IP Logged
ya i was looking every where but cant find one
Mark Mizenko
Copper - Posts: 460
Posted: May 04, 2010 at 11:49 AM / IP Logged
If it's all quiet, can you hear the relay clicking, can you locate the relay?
Did you remove the underdash panel on the drivers side?
lynnboy021
Copper - Posts: 66
Posted: May 04, 2010 at 2:09 PM / IP Logged
thanks guys all set it was a lose wire for the lights touching the ground
