astrostart problem
dsorensen11
Member - Posts: 18
Posted: July 08, 2010 at 1:28 PM / IP Logged
I have an old (~13 yrs) astrostart 120 that quit working a while ago. The module doesn't receive any signal from the remotes. I can get the module to start the car but not from a remote command. Both remotes work fine. I think it is either the brain or the antenna but I can't find a replacement for either even though the brain was supposed to have a lifetime warranty. Does anyone have an old antenna or module they want to get rid of or any other suggestion on how I should proceed?
KarTuneMan
Platinum - Posts: 7,056
Posted: July 08, 2010 at 10:22 PM / IP Logged
What does this statement mean exactly?
dsorensen11
Member - Posts: 18
Posted: July 09, 2010 at 3:52 PM / IP Logged
If I pulse the trigger start/stop input, it initiates start up and works fine. I can not initiate start up from the remote however. There seems to be no communication between my remotes and the main module.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
