2007 ford e350 superduty van
relsr
Posted: July 10, 2010 at 12:44 PM / IP Logged
Does anyone have the security wiring diagram for this vehicle? Also any other diagrams would be greatly appreciated. Thanks in advance.
brent w
Member - Posts: 26
Posted: July 10, 2010 at 1:20 PM / IP Logged
 MODEL  YEAR(S)
 ECONOLINE  2004 -2008
 KEY  T-HARNESS  IMMOBILIZER
  N/A   FD-2 (2004-2005 ONLY)   N/A
 PART   COLOR  LOCATION
 12 VOLT CONSTANT   (3) LIGHT GREEN/ PURPLE (+)   IGNITION SWITCH HARNESS
 STARTER  WHITE/ PINK (+)  IGNITION SWITCH HARNESS
 STARTER 2  N/A
 IGNITION 1  PINK/LIGHT GREEN (+)  IGNITION SWITCH HARNESS
 IGNITION 2  BLACK/ LIGHT GREEN (+)  IGNITION SWITCH HARNESS
 IGNITION 3
 ACCESSORY /HEATER BLOWER 1  GRAY / YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2  RED (+)  IGNITION SWITCH HARNESS
 KEYSENSE  N/A
 PARKING LIGHTS ( - )  N/A
 PARKING LIGHTS ( + )  BROWN (+)  @ HEADLIGHT SWITCH
 POWER LOCK  RED (TYPE C) See NOTE *1  IN EITHER KICK PANEL
 POWER UNLOCK  BROWN (TYPE C) See NOTE *1  IN EITHER KICK PANEL
 DOOR TRIGGER  See NOTE *2  @ EITHER DOOR PIN SWITCH
 DOMELIGHT SUPERVISION  BLACK/ LIGHT BLUE (+), Requires Part #775 Relay  @ RELAY, to the RIGHT of the STEERING COLUMN
 TRUNK RELEASE  N/A
 SLIDING POWER DOOR  N/A
 HORN  DARK BLUE (-)  @ STEERING COLUMN HARNESS
 TACH  WHITE/ PINK  @ PCM, Pin 48, See NOTE *3
 WAIT TO START LIGHT  N/A
 BRAKE  DARK GREEN (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM   N/A
 ANTI-THEFT  N/A
 EXTRA INFORMATION
 NOTE *1 If vehicle has a FACTORY KEYLESS ENTRY, PINK / YELLOW is LOCK, and PINK/LIGHT GREEN is UNLOCK, it is a TYPE B Door Locking System, if vehicle is without a FACTORY KEYLESS ENTRY, it is a TYPE C System and you MUST TEST from the PASSENGERS LOCK/UNLOCK SWITCH this switch is the MASTER SWITCH.. NOTE *2 This vehicle has a door pin trigger for each door, the DRIVERS DOOR is a RED / PINK (-) the PASSENGER DOOR is a BLACK/ WHITE (-) and the SLIDING DOOR if equipped, is a WHITE (-) use all 3 DOOR TRIGGER wires and DIODE ISOLATE when connecting to an ALARM SYSTEM. To connect, See DIAGRAM NOTE *3 The PCM (Powertrain Control Module) is located under the hood, next to the Brake Master Cylinder. On Diesels the TACH wire is in Pin 1, top of plug, WHITE/ PINK wire.
or
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
relsr
Posted: July 10, 2010 at 7:30 PM / IP Logged
Thank you very much!
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
