viper 5701 on 1997 honda civic
ksadam
Member - Posts: 6
Posted: July 10, 2010 at 8:11 PM / IP Logged
Hey guys I'm trying to get my alarm installed on my 97 Civic w/auto trans. The alarm part went smoothly but not the remote start. I can start the car with the key and press the remote start and it will stay running when the key is removed and shutdown with the remote. It will not however remote start alone with the remote. The parking lights and guage come on but no attempts to start. If you guys could look over my wiring diagram or if you have any suggestions that would be great.
H1 MAIN HARNESS
RED / WHITE/ /////////TRUNK RELEASE OU///////////////NO CONNECTION
RED / //////////////////////12VDC CONSTANT IN/////////////CONSTANT 12V FUSE BOX
BROWN / /////////////////SIREN OU////////////////////////////////RED(SIREN)
WHITE/ BROWN / ////PARKING LIGHT ISO WIRE/////NO CONNECTION
BLACK/ ///////////////////CHASSIS GROUND
VIOLET///////////////////POS DOOR TRIGGER///////////////NO CONNECTION
BLUE//////////////////////TRUNKPIN/////////////////////////////////BLUE/BLACK(DRKICK)DI
GREEN/ //////////////////NEG DOOR TRIGGER///////////////LGTGRN/RED(ABV FUSE PANEL)
BLACK/ WHITE/ //////DOME LIGHT SUP/////////////////////NO CONNECTION
WHITE/ BLUE//////////REMOTE START///////////////////////NO CONNECTION
WHITE/ //////////////////PARKING LIGHT OU///////////////////RED / BLACK(DRKICK)
ORANGE / //////////////GROUND WHEN ARMED OU
H3 REMOTE START HARNESS
PINK//////////////////BLACK-YELLOW
RED-WHITE/ //////WHITE
ORANGE / ///////// / YELLOW
VIOLET//////////////STARTER SIDE BLACK-WHITE
GREEN/ /////////////KEY SIDE BLACK-WHITE
RED / //////////////////WHITE
PINK-WHITE/ /////WHITE BLACK
PINK-BLACK/ /////NO CONNECTION
RED-BLACK/ //////WHITE
BLUE/////////////////UNLOCK OUTPUT(500mA)
GREEN/ /////////////LOCK OUTPUT(500mA)
H2 HARNESS
LGTGREEN/ BLACK/ //////OE ALARM DISARM//////////////NO CONNECTION
ORANGE / BLACK/ //////////AUX 4 OU////////////////////////////NO CONNECTION
GREEN / WHITE     //////////////OE ALARM ARM/////////////NO CONNECTION
VIOLET/BLACK/ /////////////AUX 2 OU//////////////////////////NO CONNECTION
WHITE/ BLACK/ //////////////AUX 3 OU/////////////////////////////NO CONNECTION
WHITE/ VIOLET/////////////AUX 1 OU/////////////////////////////NO CONNECTION
GREY/BLACK/ ///////////////DIESEL WTS IN///////////////////NO CONNECTION
BROWN / BLACK/ ///////////HORN HONK OU/////////////////GRAY(BEHIND RADIO)
VIOLET/WHITE/ /////////////TACH IN//////////////////////////////BLUE W SILVER DOTS(BACK OF CLUSTER)
DARK BLUE///////////////////STATUS OU////////////////////////NO CONNECTION
PINK/WHITE/ //////////////////FLEX RELAY CONT////////////NO CONNECTION
ORANGE / //////////////////////ACC OU////////////////////////////////NO CONNECTION
PURPLE / ///////////////////////STARTER OU///////////////////////NO CONNECTION
PINK//////////////////////////////IGNITION 1 OU     ////////////////////NO CONNECTION
GREY////////////////////////////HOOD PIN IN
BLUE/WHITE/ ////////////////2ND STATUS/REARDF OU////[REAR DEFOGGER]
BROWN / ///////////////////////BRAKE SHUTDOWN IN/////////GREEN / WHITE(BRAKESWITCH)
BLACK/ WHITE/ /////////////NEUTRAL SAFETY IN////////////EMERGENCY BRAKE WIRE
tedmond
Gold - Posts: 4,610
Posted: July 10, 2010 at 8:24 PM / IP Logged
did you see the diagnostic codes as to why it did not start?
make sure u have the nss wire connected and switch turned to on.
your start wires look correct to me.
Ted
Compustar Expert
tedmond
Gold - Posts: 4,610
Posted: July 10, 2010 at 8:26 PM / IP Logged
make sure the unit is still functioning.
take a meter, set to 20vdc, black to ground and red to purple start wire.
test to see if its giving a voltage when it cranks. if he does, you must have the green and purple wire reversed
remember, purple is going to the motor so it will go on the end of the wire going towards the fuse box.
Ted
Compustar Expert
ksadam
Member - Posts: 6
Posted: July 11, 2010 at 4:27 PM / IP Logged
no code for no start, just the error tone on my remote. the nss switch is installed and in the on position. I'll have to test the voltage to see if this is the case. thanks for the input thus far
smokeman1
Platinum - Posts: 1,589
Posted: July 11, 2010 at 7:45 PM / IP Logged
I would take the NEUTRAL SAFETY , BLACK/ White wire on the H2 Harness and put it to the chassis ground of the car.  You should be getting some sequence of flashing parking lights to indicate what is failing. If not, is the fuse installed for the parking light curcit? Little door on top of the brain box.
5 flashes - Brake wire is active
6 flashes - Hoodpin wire is active
7 flashes - Manual transmission mode is enabled and not initialized.
8 flashes - Neutral safety wire has no ground or the neutral safety is Off.
Is the remote starter in the "AUTOMATIC" mode?
Looking at your heavy gauge harness connections H3:  Looks like a couple of the wires might be incorrect.  Test and verify each wire .
12volt constant (WHITE)  to RED / White, Red, and RED / Black
Starter (BLACK/ WHITE) to Violet on starter side of wire and Green to Key Side of wire.  Starter wire is cut and spliced into Violet and Green.
Ignition (BLACK / YELLOW) to Pink
Igniton 2 (YELLOW) to Pink/White.
Accessory (WHITE/ BLACK) to Orange
smokeman1
Posted: July 11, 2010 at 8:08 PM / IP Logged
Constant 12V+ White  Ignition Switch Harness
Starter BLACK/ White  Ignition Switch Harness
Ignition BLACK / YELLOW  Ignition Switch Harness
Ignition 2 Yellow  Ignition Switch Harness
Accessory WHITE/ Black  Ignition Switch Harness
ksadam
Member - Posts: 6
Posted: July 11, 2010 at 10:47 PM / IP Logged
Alarm is in automatic mode, I'll try the chassis ground for the neutral safety wire. I'm going to also double check the heavy guage wiring. The alarm and lights and everything works, the only problem is when trying to start with the remote, parking lights and guage turns on but no start, then I get the error tone on the remote but no flashing parking lights indicating why it failed. I'm going to check those few things and then get back with you guys. I appreciate the help, glad to be a part of this community.
ksadam
Member - Posts: 6
Posted: July 18, 2010 at 11:49 PM / IP Logged
Okay so I've tested my connections and wire and fixed some errors, now I have two issues with the remote start. When I hit the remote start it starts for 2 secs then shutsdown, does this three times and then an error tone on my remote. Also when it begins to start when armed it triggers the alarm? Any ideas, should I use a better source for my tachometer wire than the back of the cluster, or does my alarm need to be programmed for voltage in the menu rather than tach?
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
