Viper 5701 Parking Light Output/Horn, 1998 Chevy Venture
trevonalex
Posted: July 19, 2010 at 9:42 AM / IP Logged
I recently purchased a Viper 5901 alarm and i will be installing it shortly(this is my first alarm job).Im very good with wires and repairing electronic it's just i never tried to install an alarm before.It will be going into a 1998 Chevy Venture.I've found all the wires needed for the install.I just have two question
will i need a relay for the parking light output from the Viper 5901 to my parking light wire? (the venture have a continuously grounded parking light.So 12 volts it applied to the parking light wire to turn it on.I know the Viper 5901 has a relay for the parking light output but will it be enough to hook up directly to the parking light wire.)
Also i will also like to use the Horn Honk output so when the full alarm is triggered the horn sounds too.The viper puts out a (-)200ma Horn Honk Output.The venture use a negative ground wire to activate the horn.Will i need a relay for the horn output or can i hook it up directly to the horn wire?
Will hooking up both the parking light and horn to the viper cause a problem if no relays are used?
I will appreciate any help i can get.Thanks
Mark Mizenko
Copper - Posts: 460
Posted: July 19, 2010 at 3:00 PM / IP Logged
You will NOT need relays for these connections.  The horn is (-) triggered, and the parking lights are (+), so just set the Viper for + light output.
trevonalex
Posted: July 19, 2010 at 10:20 PM / IP Logged
Thanks alot for the help Mark.You dont know how much u helped, this was holdin me back from doing the install but since i got the okay from you i will start the install this coming weekend.
