viper 5901 and dei 524n
mdem2
Posted: August 02, 2010 at 1:51 AM / IP Logged
To hook up the viper 5901 module to the 524n heavy duty actuators, do you need a relay? Ive heard of the 451m module, but was just curious if the 5901 has built in relays. The both have the blue/green wire, so I connected them, but the locks pulsate up and down real quick - no locking success.
Thanks!
Posted: August 02, 2010 at 3:15 AM / IP Logged
451 needed or of course separate relays, see diagrammes on this site. Read the installation manual.
t&t tech
Platinum - Posts: 2,622
Posted: August 02, 2010 at 1:40 PM / IP Logged
The locks pulsate when you connect directly to the unit? Yes you need a 451m, The open contacts are 20amps capable, so you may have to upgrade the 15 amp fuse supplied! Normally four after market actuators will drw slightly over the 15amp mark, dependent mostly on the way the actuator is mounted!
mdem2
Posted: August 02, 2010 at 3:40 PM / IP Logged
so do i need 2 451m's? or just one? and should i upgrade the fuse?
mdem2
Posted: August 02, 2010 at 3:41 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp~TID~121649~PN~10
is this the diagram i wannna use? whats that little squiqqle thing off to the side? ground?
t&t tech
Posted: August 02, 2010 at 4:40 PM / IP Logged
One 451 is all you need!
mdem2
Posted: August 02, 2010 at 7:49 PM / IP Logged
how does the 3 pin connector from the 451m plug into the 2pin from a 5901
t&t tech
Posted: August 02, 2010 at 9:10 PM / IP Logged
Where the white two pin connector with the green and blue wires plug in, you plug the three pin harness there!
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
