2008 jeep patriot
advanced
Copper - Posts: 207
Posted: August 27, 2010 at 9:27 AM / IP Logged
I have installed a Prestige APS-901 in a 2008 Jeep Patriot. I did it the old-fashioned way & didn't use a bypass module. Everything works fine, except that I get a horn chirp when remotely starting, after factory alarm is set.
I tried a ground pulse to keysense wire (second starter wire) (PURPLE / brown) with an 8.5K ohm resistor, but that didn't work.
Looking for ideas/solutions,
Good Enough Isn't!
Platinum - Posts: 7,828
Posted: August 27, 2010 at 9:53 AM / IP Logged
One possible way is to open the horn relay output while GWR is active.
advanced
Copper - Posts: 207
Posted: August 27, 2010 at 9:56 AM / IP Logged
That's a good idea. I could do that if there's no other solution.
Good Enough Isn't!
Mark Mizenko
Copper - Posts: 460
Posted: August 27, 2010 at 1:02 PM / IP Logged
You probably dont want to.. but a PKUMUX from DEI will take car of all the MUX requirements AND that keysense/HONK issue.   Only drawback with interrupting the horn is you'd lose your panic while running on RS.
dodgeram10
Member - Posts: 18
Posted: August 27, 2010 at 3:41 PM / IP Logged
Are you sure the PKUMUX will stop the horn honk issue ? Reason i ask is i have a 2010 dodge ram with a 5901 & chall bypass that does the same thing .
I get a horn honk on disarm & remote starting & was told the only way it can be turned off is via the dealership & the starscan tool .
Mark Mizenko
Copper - Posts: 460
Posted: August 28, 2010 at 9:47 PM / IP Logged
I dont remember the disarm honk.  But when I did my first new wrangler, that RS honk pis*ed me off, and I did the horn interrupt thing,  cause I could'nt stop it doing  the keysense resistance.  A few days later I got the PKUMUX's in and I've used them a bunch of times,   and no more honking.
advanced
Copper - Posts: 207
Posted: August 31, 2010 at 11:59 AM / IP Logged
Thanks for all the suggestions. I think maybe I didn't have the resistance just right for "keysense".
Next time I will use a PKUMUX.
Good Enough Isn't!
Platinum - Posts: 12,488
Posted: September 05, 2010 at 1:53 PM / IP Logged
The horn honk is from CANBUS when bypassing the Sentry system. Only way to bypass is relay interrupt or dealer scan tool.
advanced
Copper - Posts: 207
Posted: September 05, 2010 at 5:16 PM / IP Logged
So you are saying that the PKUMUX will not eliminate the horn chirp?
Good Enough Isn't!
Posted: September 06, 2010 at 10:22 AM / IP Logged
Yes, you have to use a relay or it back to the dealership to get it scanned out.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
