Help-System for a Miata
yeovil
Member - Posts: 12
Posted: April 17, 2003 at 9:44 PM / IP Logged
I'm doing a major renovation/customization on my Miata. All told about $10,000 including stereo, paint, etc. I am now paranoid about having my car stolen. I know nothing about security systems and what I've read seem to be for automatics predominantly. I have a convertible that I want to have the starter and fuel pump freeze- from options I've seen listed-seems like a good idea. Does anyone have any recommendations on a particular system or the specific features that I should make sure I get. Any help is greatly appreciated.
If you're getting old-turn it up so it still sounds the same-If you can't turn it up any higher -get a bigger amp.
draasch
Gold - Posts: 2,172
Posted: April 17, 2003 at 10:53 PM / IP Logged
not sure of the yr of your car.......but this for 90-94.
let us know the yr if this is wrong..
Constant 12 volts WHITE AND WHITE IGNITION SWITCH HARNESS (ONE CIRCUIT)
Ignition 12 volts BLUE IGNITION SWITCH HARNESS
Starter BLACK/ BLUE IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) PIN SWITCH OR INTERIOR LIGHT
Trunk Pin Switch N/A
Parking Lamp RED / BLACK (+) FUSE BLOCK ("TAIL" FUSE)
Power Lock ADD ACTUATOR POWER DOORLOCKS MUST BE ADDED #204
Power Unlock ADD ACTUATOR POWER DOORLOCKS MUST BE ADDED #204
#204- See Adding Actuator Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
