2003 camry factory oem beep wire?
senpai
Posted: October 19, 2010 at 6:08 PM / IP Logged
You know the beep once lock and beep twice unlock on 5th Generation Camrys?
Anyone know the which wire under the dash?
I installed a remote start except I'd rather use the factory beep instead of the horn to lock/unlock.
Thanks! 2003 camry factory oem beep wire? -- posted image.
Platinum - Posts: 13,725
Posted: October 20, 2010 at 8:39 PM / IP Logged
If you can not find the info you need.  The following buzzer from Radio Shack will work great for your application.
http://www.radioshack.com/product/index.jsp?productid=2062403
senpai
Posted: October 20, 2010 at 8:54 PM / IP Logged
yes, I'm aware of the radioshack option, but I would like to see if I could use the factory one since it's there.
