ignition wire polarity
nick6685
Member - Posts: 14
Posted: November 05, 2010 at 8:19 AM / IP Logged
I was installing a Clifford Matrix 3.3X on a 2000 Dodge Durango. The remote start activates but sends out a negative current to the ignition wire instead of a positive. Please help!
Thack79
Silver - Posts: 526
Posted: November 05, 2010 at 8:39 AM / IP Logged
sends out a negitive current from the remote starter?? I doubt it.   both iginition wires on a durango are positive.
nick6685
Member - Posts: 14
Posted: November 05, 2010 at 9:42 AM / IP Logged
yes, the remote start sends out a negative current when I activate the remote start
Posted: November 05, 2010 at 9:55 AM / IP Logged
Have you wired the flex relay properly? RED / white to 12v+ constant etc.
nick6685
Member - Posts: 14
Posted: November 05, 2010 at 10:16 AM / IP Logged
I don't know what that is. I hooked up the ignition 1 and the starter input and output. The only wire that has constant 12volts is the main alarm power wire.
t&t tech
Platinum - Posts: 2,622
Posted: November 05, 2010 at 2:19 PM / IP Logged
I'm just curious to find out how u figured the unit is sending a negative current?
Connect all heavy gauge reds to a good power source.
Posted: November 05, 2010 at 2:43 PM / IP Logged
I can't understand the post! I think out poster needs to have the flex relay ref. the second ignition explained to him.
That's down to you Darren, since my excuse is we ain't seen them here yet. In fact I think he's feeding the pink white flex relay - output directly to ignition 2.
nick6685
Member - Posts: 14
Posted: November 05, 2010 at 2:53 PM / IP Logged
I have not hooked up any ignition 2 wires. I'm doing this myself and i have some experiance but no training. That's why i'm asking for help
nick6685
Member - Posts: 14
Posted: November 05, 2010 at 2:55 PM / IP Logged
I tested the ignition wire with a cuircit tester and it's showing a negative signal. If it was sending a positive signal, the ignition on the car would turn on.
Posted: November 05, 2010 at 3:21 PM / IP Logged
See my last post also look at installation instructions again and again etc.Ref ign 2 and flex relay.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
