autostart 2001 pontiac sunfire
spiker77
Posted: November 27, 2010 at 2:01 PM / IP Logged
put a autostart in a 2001 pontiac sunfire with a idatalink bypass module. car starts with autostart and runs great but the service engine soon light comes on along with the security one and stays on even after you put the key in the ignition and touch the brake to kill the autostart
tommy...
Gold - Posts: 1,901
Posted: December 01, 2010 at 10:43 AM / IP Logged
Make sure you powered up all the ignition and Accessory wires and see if the light goes out...Lets get a little more specific with model #'s...!
M.E.C.P & First-Class
spiker77
Posted: December 01, 2010 at 11:28 AM / IP Logged
autostart model as1775
idatalink module ADSL-DL GM1
all wiring diagrams from autostart and bulldog security are not showing a second ignition wire but i am thinking there might be one
tommy...
Gold - Posts: 1,901
Posted: December 01, 2010 at 11:38 AM / IP Logged
Battery RED (+) IGNITION SWITCH HARNESS
autostart 2001 pontiac sunfire -- posted image. Ignition 1 PINK (+) IGNITION SWITCH HARNESS
autostart 2001 pontiac sunfire -- posted image. Ignition 2 WHITE (+) IGNITION SWITCH HARNESS
autostart 2001 pontiac sunfire -- posted image. Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
autostart 2001 pontiac sunfire -- posted image. Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
autostart 2001 pontiac sunfire -- posted image. Anti-Theft Type RESISTOR BASED SYS
autostart 2001 pontiac sunfire -- posted image. Anti-Theft Descript PASSLOCK II
autostart 2001 pontiac sunfire -- posted image. Key Sense LIGHT GREEN (-) IGNITION SWITCH HARNESS
autostart 2001 pontiac sunfire -- posted image. Neutral Safety YELLOW (-) IGNITION SWITCH HARNESS
autostart 2001 pontiac sunfire -- posted image. Tachometer WHITE (-) HARNESS NEAR BATTERY IN SPLIT LOOM 2 CYL
autostart 2001 pontiac sunfire -- posted image. Speed Sense VIOLET (AC) PIN 61 PCM BEHIND DRIVERS KICK PANEL
autostart 2001 pontiac sunfire -- posted image. Parking Lights BROWN (+) AT SWITCH
autostart 2001 pontiac sunfire -- posted image. Brake Lights WHITE (+) AT BRAKE SWITCH
autostart 2001 pontiac sunfire -- posted image. Reverse Lights LIGHT GREEN (+) AT SWITCH ON TRANSAXLE
autostart 2001 pontiac sunfire -- posted image. Horn BLACK (-) HEADLAMP SWITCH
Sometimes the WHITE 2nd ignition is not as thick as the other wires...Should have power when the key is on and cranking...!
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
