ebay viper 5701 does this look right?
hunter500ky
Posted: December 06, 2010 at 6:52 PM / IP Logged
Found this on ebay
http://cgi./VIPER-5701-P-N-5202V-REMOTE-START-W-1-LED-TRANSM-/140451852439?pt=LH_DefaultDomain_0&hash=item20b3953097
Says it only comes with 1 LED transmitter fine by me. I just want to know from one of you knowledgeable people if this looks like it has everything in it that their is supposed to be.
I found a guy on CL that said he will install it for 100-150 depending on the time it takes he has all his own tools.
I have a 2006 Tacoma Double Cab V6 Automatic
Thank you very much in advance for any replies!
Platinum - Posts: 7,828
Posted: December 06, 2010 at 9:49 PM / IP Logged
Most V6 Tacoma's have a transponder type immobilizer system.  You will need a bypass module.  The DEI PKALL would be a good choice.  If you get it "online" make sure the PKALL in "Brand new in box. Never installed or used."  The PKALL can only be used once and programmed to one car.
Make sure your installer is OK with installing refurbished items you purchased online.
hunter500ky
Posted: December 07, 2010 at 7:48 PM / IP Logged
do would this work?
http://www......com/item_16118_XpressKit-PKALL.html
hunter500ky
Posted: December 07, 2010 at 7:49 PM / IP Logged
so not do
http://www......com /item_16118_XpressKit-PKALL.html
KarTuneMan
Platinum - Posts: 7,056
Posted: December 07, 2010 at 10:35 PM / IP Logged
Your a gamblin man I see. Electronics of any kind from ebay are a HUGE risk.
Good luck, and when it quits workin you can pay your "installer" MORE money to find out why. He has ZERO
liability, again.... good luck.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
