2005 scion tc clutch bypass
jrindos
Posted: January 01, 2011 at 2:46 PM / IP Logged
I have read the other post about using the relay. I have a yellow wire and a red wire in the switch. With the switch unplugged and the clutch pressed all the way down the car starts. Not sure which wires need to go into the relay. Can anyone chime in with the colors?
scrtcell
Member - Posts: 22
Posted: January 01, 2011 at 3:25 PM / IP Logged
i believe that you have another switch somewhere else tied to the linkage for your clutch, i believe the switch you are speaking about is the upshift switch
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
