remote start and airbag saturn
buzzstpoint
Member - Posts: 11
Posted: January 06, 2011 at 9:50 AM / IP Logged
With the remote start activated the Airbag light stays on.
Doing a bit a reading is says I need to power up the 2nd ignition wire.
Anyone know which wire this is? Do I tap in, or does it need to be done with a relay.
If it needs to be done with a relay, Does anyone have a drawing of this?
2002 Saturn L200 2.2L
buzzstpoint
Member - Posts: 11
Posted: January 06, 2011 at 10:22 AM / IP Logged
A little more info.
I'm told it's not Igntion2
It's an Accessory 2 wire. (Brown and Ignition harness.)
But some say I need to power this as well with a relay.
The WHITE/ Black (From remote Start) goes to Orange (At ignition switch (Accy1))
From what I understand, I need to tap the WHITE/ Black (From RS) to Brown (At Ignition Switch (Accy2))
Can I just tap into, Or does this need to be down with a relay.
If relay is needed. How do I wire that in?
monty_77
Copper - Posts: 491
Posted: January 06, 2011 at 12:16 PM / IP Logged
your car has 2 ignition and two accessory wire all need to be powered up for everything to work right. it should be done with relays they are separate circuits for a reason, Jumping them would put extra stress on the fuses and protection process of the vehicle (to keep it from turning in to a ball of fire)
what brand and model R/S are you using we might be able to give you more help with more information.
here is the wire color, location and polarity for your car
Battery 1 Red Ignition Harness Positive
Ignition 1 Pink Ignition Harness Positive
Ignition 2 Green Ignition Harness Positive
Starter 1 Yellow Ignition Harness Positive
Accessory 1 Orange Ignition Harness Positive
Accessory 2 Brown (1) Ignition Harness Positive
Parklights Negative Lt.Blue At Light Switch Negative
Brake Lights Lt.Blue At Brake Switch Positive
Horn Blue At Steering Column Negative
Tach White At PCM Module Interface 6 cyl
Lock RED / Black Driver's Kick Panel Positive
Unlock ORANGE / Black In Driver's Kick Positive
Trunk Black At Trunk Switch Positive
Driver Door Unlock Tan Driver's Kick Panel Reverse
E-Brake Lt-Blue At Parking brake Switch Negative
Clutch Purple At Clutch Switch (2) Positive
Disarm See Diagram
Rearming RF Only
Trunk Pin RED / Black BCM Module (mounted to top of glove Box) Negative
KeySense Lt Green Ignition Harness Negative
Door Pin FL Gray/Black BCM Module (mounted to top of glove Box) Negative
Door Pin RL BLACK/ White BCM Module (mounted to top of glove Box) Negative
Door Pin FR BLACK/ White BCM Module (mounted to top of glove Box) Negative
Door Pin RR BLACK/ White BCM Module (mounted to top of glove Box) Negative
Passlock R-Code Yellow At Ignition Switch
Passlock Commun ORANGE / Black At Ignition Switch Negative
Rear Defogger Lt-Blue or White At Deffroster Switch Negative
buzzstpoint
Member - Posts: 11
Posted: January 06, 2011 at 1:28 PM / IP Logged
The RS is a Bulldog 1200 series.
I think I may have it.
I have the ignition wires wired up. But there is only one Acc wire on the RS and one (-) out while running wire.
I've done some reading, Let me see if this is correct to power up the 2nd acc wire
Relay:
85 - Ground out while running (From Remote Start (Isolate with Diode))
86 - WHITE/ black Accessory 1 (From Remote start)
87 - 12v Constant
30 - Brown Accessory 2 (At Ignition switch
Does that look correct?
monty_77
Copper - Posts: 491
Posted: January 06, 2011 at 3:04 PM / IP Logged
yes that looks good and it should work
glad to see you got the diode in there most miss that.
just make sure that your 12 volt is fused for safety
buzzstpoint
Member - Posts: 11
Posted: January 06, 2011 at 4:59 PM / IP Logged
I'm more of a visual person, so if anyone has this issue.
I made a diagram.
Here's the image
remote start and airbag saturn -- posted image.
If image doesn't show up, Here's a link to it.
https://i12.photobucket.com/albums/a243/computervitals/Misc/ACCY2Relay.jpg
monty_77
Copper - Posts: 491
Posted: January 06, 2011 at 7:41 PM / IP Logged
looks good to me
