remote start wiring, 2001 isuzu rodeo
longfoot
Member - Posts: 46
Posted: January 17, 2011 at 6:19 PM / IP Logged
I was wondering if anyone has a wiring diagram for a 2001 isuzu rodeo to hook up remote starter this site does have that year thanks if anyone can help me that would be great
buick1971
Twelvoltz
Platinum - Posts: 2,384
Posted: January 17, 2011 at 6:33 PM / IP Logged
From Audiovox:
          #5430: 2001 ISUZU RODEO 2DR SUV SPORT
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          WHITE/ BLUE          (+)          RADIO HARNESS
     Accesory          YELLOW/RED          (+)          RADIO HARNESS
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          BLUE/WHITE          (+)          RADIO HARNESS
     LF Speaker (+)          BLUE/GREEN
     LF Speaker (-)          GRAY/BLACK
     RF Speaker (+)          RED / GREEN
     RF Speaker (-)          BROWN / BLACK
     LR Speaker (+)          BLUE / YELLOW
     LR Speaker (-)          GRAY/WHITE
     RR Speaker (+)          RED / YELLOW
     RR Speaker (-)          BROWN / WHITE
     Amp Location          NOT LIKELY
     Steering Cntrls          NO
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          BLACK          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK/ WHITE          (+)          IGN SW HAR
     All Door Trigger          RED / GREEN          (-)          DRIVER'S KICK PANEL
     Trunk Trigger          N/A
     Hood Trigger          N/A
     Alarm Disarm          N/A
     Parking Lights          GREEN/ RED          (+)          AT LIGHT SWITCH OR DIMMER SWITCH
     Convenience
     Headlights-Lo          RED / BLUE          (-)          ABOVE DRIVER'S KICK
     Wipers-Lo          BLUE          (-)          AT WIPER SWITCH
     Remote Start
     Accessory 1          BLUE          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Descript          NONE
     Tachometer          BLUE 4CYL          (-)          BLK/RED(-) 6CYL AT COIL OR MULTI COIL PA
     Speed Sense          WHITE/ GREEN          (AC)          DRIV KICK 22 PIN CONN POS 5
     Brake Lights          RED / BLUE          (+)          AT BRAKE SWITCH
     Reverse Lights          RED / YELLOW          (+)          IN HARNESS IN DRIVER KICKPANEL
     Horn          GREEN/ RED          (-)          AT STEERING COLUMN "HIGH CURRENT USE RLY
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          N/A          (-)          IN HARNESS IN DRIVERS KICKPANEL
     PowerLock          N/A          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
