05 gmc denali abs light
ziggyb222
Silver - Posts: 593
Posted: February 13, 2011 at 1:05 PM / IP Logged
Put a Ultra Start 1272 and XK01 in a 2005 GMC Denali. As with many other GM trucks made the usual connections. Truck starts and run for about 15 seconds and shut off. Using tachless mode and also I get a ABS light when in remote start. Did not power the brown wire at first so I connected to the brown and no change. I read the small orange in the harness may have to be powered also??? Any ideas guys.. Thanks in advance....
Ziggy
t&t tech
Platinum - Posts: 2,622
Posted: February 13, 2011 at 1:44 PM / IP Logged
Power it and see what happens. Won't hurt to try, if it doesn't come off, then you can post.
monty_77
Copper - Posts: 491
Posted: February 13, 2011 at 2:44 PM / IP Logged
Ignition             Pink     +     Ignition Harness
Second Ignition             White     +     Ignition Harness
Accessory             Orange     +     Ignition Harness
Second Accessory     Brown     +     Ignition Harness
Mike M2
Platinum - Posts: 2,652
Posted: February 14, 2011 at 6:40 AM / IP Logged
It's not a small orange wire, it's the same size as the rest of the ignition wires. You can get the tach right on the back of the cluster if you want to try that...
Mike M2
Tech Manager
CS Dealer Services
blanx218
Silver - Posts: 654
Posted: February 14, 2011 at 8:00 PM / IP Logged
for the truck shutting off after 15 seconds it will do that on just about any GM truck that doesnt have the brown wire connected (with a relay).
also, may be a dumb question but did you program the passlock code for the XK01?
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
