tach for remote start
gregbbb
Copper - Posts: 82
Posted: February 22, 2011 at 2:10 AM / IP Logged
Can a fuel injector be a unreliable sorce of tach?
I just installed a viper 5901 in a 2010 ford edge and I used the uncomon non blue wire of the fuel injector
for my tach.  The viper programed right up and all was good started great untill the next day the car would start
for a bit then shut off I tried to reprogram the tach learn and this time that wouldnt work so I switched to voltage sence
and the car started right up go figure?
Mike M2
Platinum - Posts: 2,652
Posted: February 22, 2011 at 6:32 AM / IP Logged
Tho it is a pulsed output, i have found they just don't always work(my own Dodge Caravan for example). It is the wire Directechs calls for...
Mike M2
Tech Manager
CS Dealer Services
Posted: February 22, 2011 at 7:29 AM / IP Logged
Any one tried either crankshaft or camshaft positional sensor at the engine management, or the best place, tach at the gauges if it is wired i.e. non data.
Thank goodness BMW and Toyota/Lexus give you a wire on the diagnostic socket (OBD 11)
tedmond
Gold - Posts: 4,610
Posted: February 23, 2011 at 9:05 AM / IP Logged
hey howie, i have used a crankshaft position sensor before. i got the compustar to program tach when the car was running, but it would never rs.
Ted
Compustar Expert
Posted: February 23, 2011 at 11:08 AM / IP Logged
I prefer the back of the tachometer except most modern cars have a chip for the instrument panel and tach is multiplexed with other functions, I've had slight grief with VW and Euro GM, their (very similar) systems don't seem to like injector pulse pick ups, they then get rough idling and pick-up and/or stalling.
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
