autopage rs 750 lcd
CraigC
Member - Posts: 16
Posted: April 23, 2003 at 2:10 PM / IP Logged
I have this unit installed and everything was working great and then the door locks stopped working. it does not lock or unlock, but it use the power locks in the car it works fine, so i am thinking it is something with alarm. any ideas????
jrilla
Gold - Posts: 1,498
Posted: April 23, 2003 at 2:57 PM / IP Logged
Check your connections. Did you solder them?
J Rilla
Owner/Installer
CraigC
Member - Posts: 16
Posted: April 23, 2003 at 10:06 PM / IP Logged
yes I did solder them
Platinum - Posts: 12,488
Posted: April 23, 2003 at 10:54 PM / IP Logged
What kind of car ? Year ? Model ? Did you test the wires to see if there is a current on them ?
CraigC
Member - Posts: 16
Posted: April 24, 2003 at 12:43 AM / IP Logged
It is in a 92 bmw 535, I haven't had a chance to test them yet, it just happened so I don't know what happened
JaysOnTheEdge
Member - Posts: 10
Posted: April 24, 2003 at 4:51 PM / IP Logged
Where can i get a autopage  rs-750, it looks to be the same as the Commando  FM760? are they
Posted: April 24, 2003 at 5:31 PM / IP Logged
The wire should rest at ground and when toggled the wier should read 12 volts. Also, Do not operate locks by remote with door open or deadbolted to prevent possible damage to servos.  The Commando FM760 & the RS-750 are the same units.
brianh
Silver - Posts: 518
Posted: April 25, 2003 at 7:36 PM / IP Logged
The Autopage is the same as the Commando 760. I carry a full line of Commando products. The Marksman is also the same unit. Brian
