2008 g37 push button start turbo timer
dvaldez0989
Copper - Posts: 98
Posted: March 30, 2011 at 1:12 PM / IP Logged
i recently installed the viper 5902 on a g37 with the push button start. everything works great. the only problem i am having is with the turbo time. when i activate the turbo timer from the alarm, the vehicle will not let me turn off the ignition since the rs is feeding it power. in result the time expires and the car remains on. any easy fix for this?? thx in advanced.
syl20rochon
Copper - Posts: 298
Posted: May 08, 2011 at 7:58 PM / IP Logged
So, if you're pressing on the button, you're car remain on because of the remote starter and will not shut down after timer is done OR you do not press on the button like if your were to shut down the car. Which bypass did you use? You have to remember that the turbo feature is a remote starter take over, you should be pressing your button as if you were to close the car.
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
Monday, October 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
