clifford matrix rsiii remote programming
chriswallace187
Gold - Posts: 1,661
Posted: April 22, 2011 at 10:31 PM / IP Logged
Customer has a Clifford Matrix RSIII alarm/RS combo in a vehicle he purchased, along with a 478V/P/C remote that as far as I can tell is the correct one for this system.
Remote's apparently not communicating with the alarm control module, which has power and goes into valet mode so it's probably OK.
Anyone have the following, in order of awesomeness if you do?
1. PDF manual for this unit. Not yet in the downloads section here.
2. Programming instructions for this remote to this alarm.
3. Other helpful advice
Thanks in advance!
C Renner's Auto Electronix
chriswallace187
Gold - Posts: 1,661
Posted: May 05, 2011 at 5:25 PM / IP Logged
Ok, second question regarding the same car. Anyone able to verify that the 479V is backwards compatible with this, or the Viper 790XV?
The remote transmitter was the problem in this case - there are 2 separate PC boards in the transmitter, and the pins on the connector that goes between them had come un-soldered.
blanx218
Silver - Posts: 654
Posted: May 05, 2011 at 9:49 PM / IP Logged
Based on DEI's transmitter look up tool, the 479 will work. key on, push release push and hold valet button, siren chirps,  press lock button, siren chirps again. you're now programmed
chriswallace187
Gold - Posts: 1,661
Posted: May 06, 2011 at 10:04 AM / IP Logged
Sorry, I should have been more specific.
What I meant to ask was more along the lines of "Has anyone actually programmed a 479V to an alarm that originally came with a 478?"
blanx218
Silver - Posts: 654
Posted: May 06, 2011 at 12:32 PM / IP Logged
Well, being that DEI doesn't sell the 478 remote anymore and have the 479 as its direct replacement, I would be confident that it will work. But to answer your question, no I haven't actually done it.
Posted: May 06, 2011 at 1:26 PM / IP Logged
email me please I'll send you the pdf, you appear to have changed your email address.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
