viper 451m 98 grand voyager
Member - Posts: 18
Posted: September 15, 2011 at 11:03 PM / IP Logged
Can someone please help me with the 451m unlock relay. i have gotten everything else on the alarm to work except the door lock and unlock. i am just unclear as to where the wires go. there is a purple wire for the 12v and then there is a WHITE/ black, BROWN / black, GREEN/ black, and a blue/black those are the ones i am lost about. the car only has one wire that locks and unlocks the doors and that is a GREEN / WHITE wire. Please and thank you for the help i appreciate it!
Mike M2
Platinum - Posts: 2,652
Posted: September 16, 2011 at 6:21 AM / IP Logged
Ok, you don't use the WHITE/ black or the BROWN / black so tape them off. The purple goes to ground. A 1500ohm resistor goes on the GREEN/ black, a 250ohm resistor on the blue/black. Tie the other ends of the resistors together as they both go to the GREEN / WHITE in the van.
If you have a factory alarm, use a 4020 for lock and a 665 for unlock in place of the other ones.
Mike M2
Tech Manager
CS Dealer Services
11357923
Member - Posts: 18
Posted: September 22, 2011 at 12:19 PM / IP Logged
thanks i am going to try what you said and get back to you
11357923
Member - Posts: 18
Posted: September 23, 2011 at 12:03 AM / IP Logged
thank you very much dude everything works the way they should
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
