2003 f250 viper 5901
sacredcreationz
Member - Posts: 21
Posted: September 19, 2011 at 12:55 PM / IP Logged
Hello all,  back to Viper 5901 wiring and their darn flex relays.  Actually all I need is a correct wiring diagram for the F250 start circuit.  I have gone through close to 10 different wiring diagrams.  All with different colors that don't match the truck.  Really stupid that I can't edit them on this site.  But anyways the delimma.  I believe I have three ignitions.  That is a problem because the 5901 only comes equiped to handle 2.
So here is my wiring leading to the ignition switch in the steering wheel.
I have (4) wires that have a constant 12v with car off.
Yellow, another yellow, BLACK/ orange, and GREEN/ violet
acc = dark blue/green
start = green
Ign = RED / black, grey/ yellow, white yellow
any ides?  My only thought is that because the WHITE/ yellow ignition is a smaller wire that it may not be immediately needed during the remote start process, like maybe it gives power to systems that aren't used unless driving like cruise, wipers, ect. Anyone have an accurate diagram for a 2003 f250 deisel?
chek
Copper - Posts: 69
Posted: September 19, 2011 at 6:45 PM / IP Logged
12 VOLT CONSTANT YELLOW (+) and LIGHT GREEN/ PURPLE (+) @ IGNITION SWITCH HARNESS
STARTER DARK GREEN (+) @ IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 WHITE/ YELLOW or RED / LIGHT GREEN (+) @ IGNITION SWITCH HARNESS
IGNITION 2 RED / BLACK (+) @ IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 GRAY / YELLOW (+) @ IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 DARK BLUE/LIGHT GREEN (+) @ IGNITION SWITCH HARNESS
chek
Copper - Posts: 69
Posted: September 19, 2011 at 6:48 PM / IP Logged
Some wiring charts list three ignitions but its really two ignitions and two accessory wires.
chek
Copper - Posts: 69
Posted: September 19, 2011 at 6:57 PM / IP Logged
BTW the above wiring chart is from Bulldog  website. Support them when you can, they have very nice wiring charts, all free.
sacredcreationz
Member - Posts: 21
Posted: September 19, 2011 at 8:47 PM / IP Logged
Unfortunately that diagram is incorrect.  There is only one acc.  and 3 ign.  I know I verified with a multimeter.  But I found that the 5901 has outputs to more relays to control more igns, starts, or acc.
chek
Copper - Posts: 69
Posted: September 19, 2011 at 8:59 PM / IP Logged
OK cool.......as long as you mimic exactly what the ignition switch does as you cycle it all the way thru crank and back to run you should be good to go...............
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
