resistor passlock bypass
surovich
Member - Posts: 31
Posted: October 08, 2011 at 1:41 PM / IP Logged
Im hoping someone can confirm something for me - I did a reading on my car and the OHMs during start were 4.5k, I had a 4.7k resistor around so I used that to bypass the passlock.  This is all working great, car starts with the remote and the key - but my yellow security light stays on at all times - should I worry about this?
Saturn Vue 2007 by the way.....
Scott
surovich
Member - Posts: 31
Posted: October 08, 2011 at 2:12 PM / IP Logged
Sorry, I did more searching and some people say just use a 2.2k resistor instead?  If my value was off, I shouldnt start with the remote start, right?
Platinum - Posts: 7,827
Posted: October 08, 2011 at 7:44 PM / IP Logged
The resistor value is different from car to car.
Did you use the steps in this guide to determine the value?  http://documents.audiovox.com/700054.pdf
Did your relay setup and wiring look like the diagram?
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
