astrostart 2100 problems
chevyman14
Member - Posts: 22
Posted: January 08, 2012 at 9:08 AM / IP Logged
Hello I just bought a new vehicle and it has the astrostart 2100 in it,when you try to start it,it will just start and shut off right away,then everything goes off then a few seconds later it will try to start agian, same thing happens it does this 3 times and then there is nothing. there is no lights that blink on the unit.
Any thoughts? Looks like there is a brand new battery in the vehicle could that have something to do with it? Also tried to put the key in the igintion and try and same thing happens?
Platinum - Posts: 13,725
Posted: January 08, 2012 at 9:15 AM / IP Logged
Try placing the key in the ignition and turn the switch to the on position.  Then attempt to remote start it, what happens now?
chevyman14
Member - Posts: 22
Posted: January 08, 2012 at 9:30 AM / IP Logged
Same thing happens starts and shuts off right away, I can start it with the key and then push the start and it will do the contunious run, like it should then I hit the brake and it shuts off like it should.
Posted: January 08, 2012 at 9:49 AM / IP Logged
DId you turn the key to the run position?
chevyman14
Member - Posts: 22
Posted: January 08, 2012 at 9:51 AM / IP Logged
Yep I put it in the run so the radio and stuff came on, then tried and it did the same thing as if there was no key in it at all,
Posted: January 08, 2012 at 11:36 AM / IP Logged
You need to investigate the Tach wire connection.
chevyman14
Member - Posts: 22
Posted: January 08, 2012 at 1:04 PM / IP Logged
Were is that located? I might just bring it in
chevyman14
Member - Posts: 22
Posted: January 08, 2012 at 4:44 PM / IP Logged
OK so I just went out and found were the tach wire went to, they tapped into the wire that comes from the tach in the dash, I took the unit out and then tried to start it and it did not start but after the 3 times of tring it did flash 10 times. what does the flashes mean?
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
