viper 5704, 02 blazer, door lock, dome
roadrage2006
Posted: February 11, 2012 at 11:18 PM / IP Logged
Hello everyone! I'm in stalling a Viper 5704 remote start into a 2002 Chevy S10 Blazer and I need a little help with a few items:
1.For the power locks can I connect the alarm directly to the light blue and white wire at the BCM or will I need relays like the DEI451M?
2.Should I wire the OEM alarm disarm and arm wires or the disarm only?
3.If I wire the domelight supervision wire to the LF door trigger do I need to use a relay there or diode isolate. Would I be better off hooking up to the interior light by the steering wheel with a relay?
Thanks for any help, Jack.
gabedemelo
Copper - Posts: 64
Posted: February 11, 2012 at 11:35 PM / IP Logged
you need 451 for doorlocks since theyre + plus put the GREEN/ black disarm wire to the light green vehicle disarm,..... all wires can be found in the large harness under drivers dash,... tach can be found in taped harness to the far right under drivers dash a little lower than the large harness sort of below center console but easily accessible from drivers dash
Item     Wire Color     Polarity     Wire Location
12 Volts     RED / white (50A)     +     ignition harness
Second 12 Volts     red (40A)     +     ignition harness
Starter     yellow     +     ignition harness
Second Starter     N/A
Ignition     pink     +     ignition harness
Second Ignition     white     +     ignition harness
Third Ignition     N/A
Accessory     orange     +     ignition harness
Second Accessory     brown     +     ignition harness
Third Accessory     N/A
Keysense     lt. green     -     ignition harness or BCM, lt. blue plug, pin B9
The BCM is in the center console, below the radio.
Data Bus     yellow (resistor code), ORANGE / black (ground)     Passlock 2     Passlock sensor on ignition key cylinder
Can Bus High     N/A
Can Bus Low     N/A
Can Bus Sw     purple (J1850 Class 2 Serial Data)     data     data link connector, black 16 pin plug, pin 2
Power Lock     lt. blue     +     BCM, brown plug, pin A4
Power Unlock     white (all doors); lt. green (driver door only)     +; -     BCM, brown plug, pin A3; lt. blue plug, pin A4
Lock Motor     gray     5 wire     dash relay block next to dash fuse block
Driver Unlock Motor     tan     5 wire     dash relay block next to dash fuse block
Parking Lights (-)     white     -     BCM, lt. blue plug, pin A5
The BCM is in the center console, below the radio. This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground.
Parking Lights (+)     lt. blue     +     dash relay block next to dash fuse block
Hazards     same as turn signals
Turn Signal (Left)     lt. blue/white (F), yellow/black (R)     +     turn signal switch
Turn Signal (Right)     dk. blue/white (F), dk. GREEN / WHITE (R)     +     turn signal switch
Headlight     white     +     BCM, lt. blue plug, pin A11
AutoLights
Reverse Light     lt. green     +     driver kick, harness to rear
Left Front Door Trigger     tan     -     BCM, purple plug, pin B4
Right Front Door Trigger     orange     -     BCM, purple plug, pin B2
Left Rear Door Trigger     dk. blue/white     -     BCM, lt. blue plug, pin B11
Right Rear Door Trigger     same as left rear door trigger
Dome Supervision     gray/black     -     BCM, lt. blue plug, pin A3
Trunk/Hatch Pin     see rear glass pin
Rear Glass Pin     pink/black     -     BCM, lt. blue plug, pin B10
Hood Pin     N/A
Trunk/Hatch Release     black (rear handle switch)     -     BCM, purple plug, pin B1
Trunk Release Motor     BLACK/ white     +     dash relay block next to dash fuse block
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     lt. green (driver door key cylinder)     -     BCM, purple plug, pin B3
Disarm No Unlock     see factory alarm disarm
Trunk Alarm Shunt     N/A
Tachometer     white     ac     instrument cluster, gry 24 pin plug, pin A3 or PCM, grn plug, pin 10
The PCM is on the passenger side fender.
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     PURPLE / white     +     clutch switch
Fuel Pump     gray     +     underhood fuse block, red 32 pin plug, pin F1
Rear Defroster     white     - latched     HVAC Control, blue 4 pin plug, pin 3
Mirror Defroster     same as rear defroster
Left Front Heated Seat     pink     + resistor     driver heated seat switch
Right Front Heated Seat     pink     + resistor     passenger heated seat switch
Speed Sense     dk. GREEN / WHITE     ac     BCM, lt. blue plug, pin B1
Brake Wire     white     +     brake switch or steering column
Parking Brake     lt. blue     -     parking brake switch or BCM, brown plug, pin B10
Horn Trigger     black     -     horn switch or BCM, brown plug, pin A9
The BCM is in the center console, below the radio. The horn trigger wire is available at the BCM only on vehicles with factory alarm.
GreenGables
offroadzj
Gold - Posts: 2,043
Posted: February 11, 2012 at 11:38 PM / IP Logged
1) If the unit has dual polarity lock outputs (switch wires for positive output) then you can try connecting them straight to the light blue and white wires. But chances are you will need the 451m to control the (+) locks.
2) Do you have a factory alarm? If not then don't worry about it; if you do and you don't care about having it arm with the aftermarket remote than don't worry about the factory arm. Still connect disarm so you don't have to worry about the alarm accidentally going off.
3) You shouldn't have to worry about the domelight supervision. I'm pretty sure that the BCM will automatically turn on the domelight when the doors are unlocked. You can test it by watching the light when locking / unlocking the vehicle with the remote.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
gabedemelo
Copper - Posts: 64
Posted: February 11, 2012 at 11:49 PM / IP Logged
dome supervision wont work while vehicle is running when you unlock unless you use dome sup,... dei stopped using the flipflop +/- lock wires quite a while ago not sure why but im assuming to sell more products
GreenGables
roadrage2006
Posted: February 12, 2012 at 12:00 AM / IP Logged
Thanks guys, I have been pulling my hair out trying to figure these last few items out!!!!!!!!!!!
offroadzj
Gold - Posts: 2,043
Posted: February 12, 2012 at 11:16 AM / IP Logged
Ahhh... I wasn't aware of the domelight supervision being off when started. I guess a connection is required.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted: February 12, 2012 at 12:00 PM / IP Logged
The reason they dropped the flip flops is they were sick of having to tell the fools to install conditioning diodes every time they fed to a processor or relay because of back feeds. And of course they sell more 451s
roadrage2006
Posted: February 12, 2012 at 4:12 PM / IP Logged
The install is going good and I am hoping to get this wrapped up tonight. The door locks worked our great using the 451m. For the dome light supervision I am planning on using pin A3 which is the gray/black wire on the BCM that controls the courtesy lamp relay. When I ground this pin I can hear the relay under the dash click and the dome light comes on. Is it ok to run the dome light supervision wire directly to this since it seems to just be a relay trigger or do I need to hook up a relay?
Posted: February 12, 2012 at 4:44 PM / IP Logged
Run it directly but use a diode, 1N4004 in line, band towards 5704.
