95 civic, viper 5704 i
brosco81
Posted: March 15, 2012 at 6:52 PM / IP Logged
I'm trying to install this on a 95 honda civic and need some help figuring this out
Need help wiring in the h3 harness
Pink- Ignition 1 input/output
RED / White- fused (30a) ignition 2 input
Orange- Accessory output
Violet- Starter output
Green- starter input
Red- fuse (30a) ignition 1 input
Pink/White- Ignition 2 output
Pink/Black- flex relay input
RED / black- fuse(30a) accessory/ starter input
Platinum - Posts: 7,828
Posted: March 15, 2012 at 8:01 PM / IP Logged
Info from DEI.
Viper H3         95 Civic Ignition Switch Harness
Pink- Ignition 1 input/output              BLACK / YELLOW
RED / White- fused (30a) ignition 2 input                  White
Orange- Accessory output        Yellow
Violet- Starter output              BLACK/ White  **
Green- starter input               BLACK/ White  **
Red- fuse (30a) ignition 1 input                    White
Pink/White- Ignition 2 output            WHITE/ Black  ***Set Flex Relay to Acc2  -   Menu 3, Item 8, Opt 2
Pink/Black- flex relay input     Not Used
RED / black- fuse(30a) accessory/ starter input       White
** If you want Starter Kill, cut this wire, connect Violet to vehicle side & Green to IGN switch side.
** If you don't want this feature, only connect the Violet wire to the un-cut vehicle Starter wire.
The White wire is rated at 50 Amps and capable handling all three Viper power connections.
smokeman1
Platinum - Posts: 1,589
Posted: March 15, 2012 at 8:16 PM / IP Logged
Here is a link to BulldogSecurity for your vehicle:
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
From your H3 harness,  Red and RED / Black to 12 Volts(White),..Pink to Ignition (BLACK / YELLOW),  Orange to Accessory(Yellow),
Violet and Green to Starter( BLACK/ White)  TWO WAYS to do this one.  Either use only the violet and NOT cut the starter wire, OR cut the starter wire, connect the Green to the KEY side of the wire and the Violet to the STARTER side of that wire.
Test and verify all wires on the vehicle before connecting any wires. Wiring diagrams are only a guide and vehicle wiring may be different.
Pink/Black..Pink/White and RED / White should not be needed.
brosco81
Posted: March 18, 2012 at 6:30 PM / IP Logged
Got it all wired in but my parking lights are flashing 7 times indicating that Manuel transmission mode is enabled and not initialized
Posted: March 18, 2012 at 6:43 PM / IP Logged
If the car has an automatic trans, change the programming option.  Menu 3, Item 1, Opt 2.
brosco81
Posted: March 18, 2012 at 6:52 PM / IP Logged
It's a manual trans..
Posted: March 18, 2012 at 7:44 PM / IP Logged
Due to the risks / liability involved with Manual Transmission Mode, there are a lot of built in safety items that must be observed.
Basically, you will need to properly bypass the Civic's clutch interlock switch ( only during a remote start ), connect all of the door/trunk status triggers, connect the Tach input, program for Tach Mode, Menu 3, Item 2, Opt 4, do a Tach Learn and connect the Neutral Safety Switch input to an appropriate signal wire.  Then you must correctly enter into Reservation Mode.  Most of that should be in the install guide.
