autopage alarm no longer unlocking doors
bgz
Posted: April 18, 2012 at 6:54 PM / IP Logged
I have a 1996 Nissan 240sx with a Autopage RF-315 alarm. I let a friend borrow my car and have had problems since. When I got the car back the alarm was set to valet mode. Once I turned off valet mode the alarm locks and unlocks the doors with the ignition on/off but the key fob no longer unlocks the doors.
I walked away and when I went to the store later the alarm worked normally when I got in. Doors unlocked with the fob and everything seemed fine. I got home and the doors didn't unlock when I turned off the car or with the unlock button but the unit does still lock the doors and arm the alarm.
What I want to know is if I should attempt to reprogram the fob/settings of if this sounds like the unit is defective. It has been working well for about two years before this incident. I have the manuals for install and operation here:
http://www.mediafire.com/?pnij9dn0o4znb
I am guessing that the unit is failing. I just would like some input before I spend the money to replace it as funds are really limited right now.
Thanks for any help that you can offer.
Posted: April 19, 2012 at 3:04 AM / IP Logged
I'm a bit confused by what you wrote,
Locks and unlocks with ignition YES/NO??
Locks and unlocks with Autopage remote YES/NO??
bgz
Posted: April 19, 2012 at 3:11 PM / IP Logged
Sorry for any confusion.
The problem has been found. Short in the unlock wire connection.
Thanks anyway though. I would delete this topic but I do not have permission to do so.
Posted: April 19, 2012 at 4:28 PM / IP Logged
Don't worry it will simply fade away! Glad you found the solution.
tommy...
Gold - Posts: 1,901
Posted: April 20, 2012 at 2:49 PM / IP Logged
Pish Posh... I hope your friend fixed it... autopage alarm no longer unlocking doors -- posted image.
M.E.C.P & First-Class
Friday, September 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
