can you remote start car and drive
saiful
Member - Posts: 8
Posted: May 05, 2003 at 5:15 AM / IP Logged
Hi can anyone tell me if it is possible to remote start a car and drive it as normal without having the key in the ignition.  I have a commando fm-760 car alarm
thanks.
saiful
cpgoose
Gold - Posts: 1,098
Posted: May 05, 2003 at 6:54 AM / IP Logged
If you install it correctly, no, you can't drive it without the key. When you hit the brake to change the gear, the car will shut off from hitting the brake. In the case where you can change the gear without stepping on the brake, I believe the steering wheel will lock.
JWorm
Platinum - Posts: 2,208
Posted: May 05, 2003 at 8:35 AM / IP Logged
If you were to get by the brake , some remote starters will also shut off when it notices an increase in tach signal (higher reving engine).
scuba1954
Member - Posts: 20
Posted: May 05, 2003 at 7:35 PM / IP Logged
....and if you could get around the tach problem, you then have to figure out how to unlock the steering wheel, then the engine will only run for a short programmed amount of time.
