2008 pilot automatic window issue
deeryders
Copper - Posts: 97
Posted: July 19, 2012 at 1:42 AM / IP Logged
My uncle has a 2008 Honda Pilot. He recently got work done on his driver side door. When the work was done the main switch rolled the windows up and down normally but did not work automatically anymore (after the second click pushed up/down). At times when he rolled the window down the window would not roll back up until after a while. He is very annoyed by this factor. I suggested him buying a new switch but that did not help. The problem for the window not rolling back up has not happened since he has gotten the new switch but the automatic roll up/down fails to work. Perhaps there is a relay that had gotten messed up? I am no familiar with this.
Thanks.
MECP Certified
Dont Ground Out!!!
Posted: July 19, 2012 at 6:14 AM / IP Logged
It might need programming/initialising.
This works on most vehicles with a (failed) one shot!
Ignition on, go to each switch in each door, HOLD down for 30 seconds then HOLD up. Should do it then repeat at the driver's door (master switches).
tommy...
Gold - Posts: 1,901
Posted: July 20, 2012 at 7:59 AM / IP Logged
Owners Manual has the reset procedure. Howie pretty much had it, though...
M.E.C.P & First-Class
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
