python 1401 upgrade to lcd remote?
lilflippy
Member - Posts: 47
Posted: October 28, 2012 at 7:35 AM / IP Logged
Hi I got a Python 1401 remote start system.
I would like to upgrade to a LCD remote.
Which remotes can I use please reply back thanks.
lurch228
Silver - Posts: 1,338
Posted: October 29, 2012 at 9:17 AM / IP Logged
The 1401 should be able to use the 7351 in 1-way with the current antenna or with the 6211t antenna/receiver you get 2-way or you can do the 7752/7941 remotes with the 6711t antenna/receiver. But Either way if you want full use of the LCD you will need to upgrade the antenna/receiver as the lcd remotes are 2 way. And the antenna shipped with the 1401 is 1 way only. Also can get the 7251 LE led 2-way remotes that will work with the 6211t antenna/receiver.
lilflippy
Member - Posts: 47
Posted: October 29, 2012 at 9:57 AM / IP Logged
Ok kool so all I have to do is change the antenna to a 6211T and get Either 7351/7752/7941 remotes. And it should work right?
lurch228
Posted: October 29, 2012 at 5:50 PM / IP Logged
There is a unit date code of 10/D (ie 10=year/D=month_April) or newer, that is on the main unit or antenna itsself that the 6211t has to have or the 7351 wont work.
The 7752/7941 remotes will only work with any 6711t antenna.
The Difference between the 2 antenna/receivers is the range 6211t is 2000-2500ft and 6711t is 1 mile.
lilflippy
Member - Posts: 47
Posted: October 29, 2012 at 9:37 PM / IP Logged
Ok if I buy the 6211T can I just switch out the antenna part and use the same cable that is already connected to the brain?
lurch228
Posted: October 29, 2012 at 10:51 PM / IP Logged
Yes, the 6111t you have is a 6 pin and so are the 6211t and 6711t. Plug in the antenna/receiver to the existing cable, and pair the new remote(s). Old remotes will work with the 6211t, only need to pair the 7351v/p/x remote. The 6711t won't work with the old remotes. Its that simple!
lilflippy
Member - Posts: 47
Posted: October 29, 2012 at 11:08 PM / IP Logged
5
Ok is there any other lcd remotes I can use?
lurch228
Posted: October 30, 2012 at 12:31 AM / IP Logged
Ther are 3 versions of each remote designated by the letter suffix. 7351v viper 7351p python ect,.
lilflippy
Member - Posts: 47
Posted: October 30, 2012 at 6:27 PM / IP Logged
What about the 544N 2Way Antenna and Python 477P
2-Way LCD remote? Would this work on my system?
lurch228
Posted: October 30, 2012 at 6:46 PM / IP Logged
There are two things, First the antenna has no led or valet switch so you would need to have a 4 pin antenna and seperate led , valet switch plus the seperate plugs on the brain.
Second In theory it should work but I've never tested it, or know of any one who has. As the serial data should be the same, with the antenna/reciever determining the remote code and frequency.
So will it work probably.
Will I guarentee it no.
Try at you own risk. That is how I figured it out.
Page of 3
