commando FM 760 install help
saiful
Member - Posts: 8
Posted: May 07, 2003 at 5:55 PM / IP Logged
Thanks for the info really appreciate it. I was wandering if you can answer a couple of other questions?
I understood that the fm-760 had 2  separate channel outputs one for the trunk which i think is the gray wire and i dont know what the other one is.  I wanted a 2nd channel so i could operate the petrol cap.
The other question is about the door lock connections,  the previous alarm installer installed a new door lock motor and control module on the drivers door to insall a basic alarm how do i use that for  2 step unlock wire connections?
I have a 93 Prelude is it worth the hassle having 2 step unlock on a 2 door car?
And finally if my car's door trigger wire is BLACK/ White ( - ) does that mean it has ground switched door locks?
Thanks again for your help much appreciated.
saiful
securinu
Silver - Posts: 772
Posted: May 09, 2003 at 1:31 PM / IP Logged
use the second door unluck wire
Joe O'Byrne
Owner / Installer
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
