dealerships
cmk0808ny
Copper - Posts: 203
Posted: January 22, 2013 at 7:38 AM / IP Logged
For the people who do dealerships, do you guys install hood pins or the shutdown toggle switches? Do you leave a owners manual for the system?
chev104275
Gold - Posts: 1,436
Posted: January 22, 2013 at 7:46 AM / IP Logged
I do hood pins and leave the owners guide but not the install guide
Posted: January 22, 2013 at 10:27 AM / IP Logged
We'd be done for not installing/connecting to existing and yes, always the owners, never the install.
How can you not do a hood pin on an R/S?
Platinum - Posts: 7,828
Posted: January 22, 2013 at 2:03 PM / IP Logged
See it often.  Just had a 2002 Oldsmobile Bravada in the shop.  An older Dealer install of a Audiovox Pro9275 R/S system with a GMDL1 door lock module and PLDATA bypass module.  Just needed the PLDATA reset and the Passlock2 re-learned.  Checked it over and there was no hood pin.  Didn't use Scotch Super 33+ electric tape either...
soundnsecurity
Gold - Posts: 2,720
Posted: January 22, 2013 at 4:37 PM / IP Logged
ive seen some horrible dealership jobs myself. the fact is that the dealership will charge the customer a crazy amount of money and then find the cheapest place to install which usually involves cheap materials, t-taps, missing connections and cut corners.
always use a hoodpin, its more of a safety feature than a security feature for when people work under your hood.
never leave the install manual, never, nothing good can come from a customer poking around in the settings menu.
KPierson
Platinum - Posts: 3,527
Posted: January 22, 2013 at 6:54 PM / IP Logged
It doesn't matter who I do work for, hood pins and tach wires get hooked up.
Kevin Pierson
lucasoil4u
Copper - Posts: 317
Posted: January 24, 2013 at 11:25 AM / IP Logged
Agree With KPIERSON! ALWAYS ALWAYS ALWAYS us tach wire and Hood pin!
racerjames76
Silver - Posts: 581
Posted: January 24, 2013 at 3:15 PM / IP Logged
We stopped doing hoodpins a while back 5-7 years i think. We are in ohio where the salt eats those hood pins alive. We are required to place a warning sticker under the hood that is bright yellow saying the vehicle is equipped with remote start device. We were replacing hoodpins at least 5 a day back then before we quit putting them in. Caused way more trouble than they were worth. Tach is hooked up unless we can demonstrate that the vehicle has bump/tip start. dealerships -- posted image.
To master and control electricity is perfection. *evil laugh*
soundnsecurity
Gold - Posts: 2,720
Posted: January 24, 2013 at 8:04 PM / IP Logged
if you cant use a hood pin then you can use a sealed mercury switch. i use them on some vehicles where a hoodpin is hard to add.
lucasoil4u
Copper - Posts: 317
Posted: January 25, 2013 at 2:48 PM / IP Logged
Yeah Sealed Mercury Switch
