2009 sebring shut down problem viper 5204
armbruster
Member - Posts: 32
Posted: February 08, 2013 at 12:32 PM / IP Logged
I installed a Viper 5204 w/DBALL D2D in a 2009 Sebring for a family member.
It has came back to me because it started failing to start, shut down diagnostics indicate it is the Hood Pin shutdown but the problem is I did not install a hood pin at the car owners request. Out of curiousity I changed the setting to "Open" instead of "Closed" so the grey wire would see negative all the time and it worked for 2 weeks - it is now back with the same issue. I could easily change the option back to "Closed" and fix it but that would not be the right way to fix it. I have installed hundreds of these things and have never ran into this issue (when no hood pin is present)
Before I tear this thing back apart does anyone have any idea where I may start?
enice
Silver - Posts: 857
Posted: February 08, 2013 at 12:37 PM / IP Logged
I strictly use Idatalink but is there an option to turn off that setting on the DBALL? It could be a glitch. I've had that happen to me on idatalink modules and what I did is just turn off that option on the module.
Eric
Audiomaxx
528 East Fordham Road
Bronx NY 10458
Compustar Top Gun Dealer Award 2012-2013
armbruster
Member - Posts: 32
Posted: February 08, 2013 at 12:54 PM / IP Logged
By what I can see there is no "option" to turn it off - just Open or Closed connection via the 5904.
offroadzj
Gold - Posts: 2,043
Posted: February 08, 2013 at 1:07 PM / IP Logged
Is the hood pin wire grounding out on anything? The hood pin is a very important safety feature and should be installed. You are just asking for trouble by not putting one in...
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted: February 08, 2013 at 4:51 PM / IP Logged
I've yet to install a DB-ALL that "saw" the hoodpin, always had to hardwire it.
Posted: February 08, 2013 at 5:48 PM / IP Logged
But test it before changing it, although the DB-ALL should sense the hoodpin through the data system if it's a factory hoodpin.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
