2008 ford expedition, clifford
jammster
Posted: February 26, 2013 at 10:51 PM / IP Logged
I have a clifford 590x2 w/evoall bypass where do these hook up? h3/1 + ignition1 input/output   h3/ 2 87 flex relay + 12v   h3/3 + accessory output  h3/ 6 ignition1 + 12 v (30 amp fuses)  h3/7 30 flexoutput( car side of ign,acc or starter wire if needed)   h3/ 8  (87a) flex relay input key side of ign,acc or starter wire side  h3/9 acc/starter relay+12v   input (30 amp fuse)        It is going on a ford 2008 expedition.
Jammster
Platinum - Posts: 7,828
Posted: February 27, 2013 at 7:44 AM / IP Logged
  2008 ford expedition, clifford -- posted image.
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT                 WHITE/ orange (+) @ ignition switch, gray 10 pin plug, pin 1
H3/2 RED / WHITE FLEX RELAY +12V INPUT (30A FUSED) red (+)  @ SJB, black 1 pin plug (C), pin 1
H3/3 ORANGE (+) ACCESSORY OUTPUT        BROWN / yellow (+) @ ignition switch, gray 10 pin plug, pin 7
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE)     blue/white (+) @ ignition switch, gray 10 pin plug, pin 10
H3/5 GREEN (+) STARTER INPUT (KEY SIDE)          blue/white (+) @ ignition switch, gray 10 pin plug, pin 10
H3/6 RED IGNITION 1 +12V INPUT (30A FUSED)                  red (+)  @ SJB, black 1 pin plug (C), pin 1
H3/7 PINK/WHITE (30) FLEX RELAY OUTPUT   ***set to ACC2        PURPLE / green (+)  ignition switch, gray 10 pin plug, pin 5
H3/8 PINK/BLACK (87a) FLEX RELAY INPUT              not used
H3/9 RED / BLACK ACC/STARTER RELAY +12V INPUT (30A FUSED)          red (+)  @ SJB, black 1 pin plug (C), pin 1
H3/10 NC No Connection
