are there any basic car alarm diagrams
samith
Posted: May 10, 2003 at 8:58 PM / IP Logged
 I am an A/V technician and I want to know if there are any basic car alarm wiring diagrams, so I get the basic idea on wiring. I want to install a basic alarm in a 97 Honda Accord with keyless entry.
Platinum - Posts: 12,488
Posted: May 10, 2003 at 9:21 PM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|BLACK/ white *3      |-  |gray conn. above fuse       |
|     POWER UNLOCK|orange *3           |-  |box in blue tape            |
|       LOCK MOTOR|WHITE/ red           |   |drivers door harness        |
|     UNLOCK MOTOR|yellow              |   |drivers door harness        |
|    DISARM DEFEAT|yellow/red          |   |passenger door harness      |
| PARKING LIGHTS +|RED / black *1        |   |blue plug fuse box          |
|       HEADLIGHTS|blue                |-  |blue plug left of column    |
|     DOOR TRIGGER|blk/wht             |-  |gray plug right of column   |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|orange              |-  |gray plug right of column   |
|  FCTRY ALARM ARM|RED / yellow          |-  |passenger kick or alarm *2  |
|FCTRY ALRM DISARM|RED / blue            |-  |passenger kick or alarm *2  |
|       TACHOMETER|blue                |   |at distributor              |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|blu/red or grn/blu  |-  |steering column             |
|           WIPERS|blue                |-  |brown plug left of column   |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/yel - blu       |A  |driver door harness         |
|  LR WINDOW UP/DN|grn/blu - grn       |A  |driver door harness         |
|  RR WINDOW UP/DN|yel/blu - yel       |A  |driver door harness         |
Notes:
*1 Also a male blade terminal is available in the fusebox DKP.  *2 Factory alarm is located under the passenger front seat.  *3 SE models, use factory alarm arm wire for lock and factory alarm disarm wire for unlock.
samith
Posted: May 11, 2003 at 6:32 AM / IP Logged
Thanks Jeff for the info.
Posted: May 11, 2003 at 8:26 AM / IP Logged
No problemo
