remote starter with a bypass
apple9
Posted: April 30, 2013 at 12:12 AM / IP Logged
I am installing a crimestopper RS00-G4 and Fortin Key overide All transponder data bypass in my  2011 camry and looking for a little help. I have the kits and relay switch. My ignition key has the letter G stamped on it. Wire locations and pictures would be a great help, thank you.
Platinum - Posts: 7,827
Posted: April 30, 2013 at 4:54 AM / IP Logged
The Fortin install guide should give you everything you need for the bypass module's connections.
https://ifar.ca/download/7551/preview.html    Here is a link to some IMI /IMO wire photos ( most Toyota's) :
http://ftp.idatalink.com/Support/toyota%20imi_imo/Main.swf
For vehicle wiring, here are some sources :
Here is a link to Bulldog Security :  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Here is a link to Ready Remote :  http://www.readyremote.com/main.asp
Here is a link to AudioVox :  http://techservices.audiovox.com/AccessRequest.aspx    Sign-up & info is free.
If you need more assistance with the Crimestopper wiring and connections, help us to help you by creating a
template with the units harness info as per this post : https://www.the12volt.com/installbay/forum_posts.asp~TID~133725~PN~1
flobee4
Silver - Posts: 585
Posted: April 30, 2013 at 7:45 AM / IP Logged
I just looked at the install manual for the Evo-all on their website. It does a nice job with showing you the exact location and colors of the wires you need to hook up. The wires it shows you are the only wire you should connect to. Do not add any more connections. An example of this is the keysense wire, traditional on toyotas you would interface with this wire to disarm the factory alarm on the car. With the Evo-all, it will disarm the factory alarm through data and if you actually interface with the keysense wire using the Evo-all it can interfere with how the Evo-all works. So, just a heads up, follow their install guide to the letter.
Also on the install guide, it mentions that the Evo-all needs to have firmware 79.03 or higher on it. This firmware is not pre-loaded on the Evo-all. So, you will need to have it "flashed" to that firmware version or newer.
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
