04 honda accord compustar 2w901ss
rcnjunsnow
Posted: May 04, 2013 at 5:24 PM / IP Logged
Hi everyone. This is my first article regarding remote starter installation. I have gained good info from here about remote start. Thanks to you guys!.
I am a mechanic and writing to ask som help or advice for my car, 2004 Honda Accord Coupe with manual tranny, Compustar 2w901ss with 6200 brain. Bypass module is Idatalink Blade Al-Ca. This is my second try, first remote installation was on my girlfriend's car, 02 Acura El but I keep having issue, error 01 that is tach learnning.  I double checked tach wire and learned tach by hoding remote start for 2.5 s and chirps.
Here is some modification that I cut GREEN / WHITE loop to bypass reservation mode, but I hooked up Compustar DAS sensor to prevent car moving when remote staring in case the tranny in gear.
Below is wires I hooked up Basic power wires, Parking light, brake switch, clutch bypass with a relay, idatalink blade wires, horn, tach wire where is on p/s
plz give me some helpful infos.
Thx for reading my issue
rcnjunsnow
Posted: May 09, 2013 at 9:42 PM / IP Logged
i just reset the bypass module and its working now...
searched from previous posts
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
