2013 dodge dart 5904/evo no start
Raymond4646
Copper - Posts: 121
Posted: July 07, 2013 at 11:55 AM / IP Logged
Evo is programed and working but when attempting to rs via the 5904 it only clicks the internal relays. However if I try to remote start with the option of pressing the factory keyless entry remote it will rs but once disarmed it will shutdown the vehicle. The option for rs shutdown when door is opened is not activated on the evo.
I tagged only the wires the evo specified on the 5904. Of course theres the remaining heavy gauge wires remaining. Any assistance would be appreciated.
dasbogie
Silver - Posts: 514
Posted: July 07, 2013 at 12:27 PM / IP Logged
is the viper set to manual transmission mode?
is the neutral safety switch plugged in and turned on?
Advanced
Raymond4646
Copper - Posts: 121
Posted: July 07, 2013 at 12:30 PM / IP Logged
Vehicle is in automatic mode and neutral saftey switch is plugged in and switch is turned on.
dasbogie
Silver - Posts: 514
Posted: July 07, 2013 at 3:39 PM / IP Logged
which heavy gauge wires do you have remaining or which did you connect?
Advanced
Raymond4646
Copper - Posts: 121
Posted: July 07, 2013 at 5:22 PM / IP Logged
All the 12volt inputs to the 5904. The other half of the starter wire and accessory wires are not tagged
dasbogie
Silver - Posts: 514
Posted: July 07, 2013 at 9:17 PM / IP Logged
Is tach signal programmed to viper? When you use the viper does it try to remote start or does it immediately flash parking light error code?
Advanced
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
