immobilised injector pulse problem
nissanpower
Member - Posts: 8
Posted: November 02, 2013 at 7:14 AM / IP Logged
Hi All,
I've just finished installing my Mongoose M80 alarm system. I used 2 of the 3 immobilisers to neutralize the injector pulse wire on injector 1 and 2.
The problem is the car seems to run a bit rougher, a little richer and not as smooth as it use to be.
(The injector circuit for this car works by negative pulse from the ECU.)
I'm thinking the alarm module is changing the signal somehow. Is it possible the immobiliser circuit in the alarm has short to ground when not armed? Or is there something else I'm missing
I haven't had the chance to diagnose it yet as it was getting late and I packed it up. But anyone with ideas or suggestions before I tackle it again would be appreciated
Cheers
racerjames76
Silver - Posts: 581
Posted: November 02, 2013 at 7:41 AM / IP Logged
Mostly replying to subscribe but I believe more information would be needed here? Car, wires used etc
You are sending out a ground pulse to interfere with the injection pulses? Not sure what you mean there..
Post a bit more info and I am sure you will get a better answer immobilised injector pulse problem -- posted image.
To master and control electricity is perfection. *evil laugh*
nissanpower
Member - Posts: 8
Posted: November 02, 2013 at 8:42 AM / IP Logged
Sorry I probably should have worded it better.
So the alarm has 3 point immobiliser, instead of wiring it up to the usual Fuel pump, Starter or Ignition circuit I wired it up to disable the injector signal.
However, this has caused slight issues with the car idling and possibly engine performance. The car is definitely running a little more richer than normal.
I believe somehow the immobiliser circuit from the alarm is altering the injector signal.
The car is a Honda Civic '99
Hope this makes more sense
KPierson
Platinum - Posts: 3,527
Posted: November 02, 2013 at 10:32 AM / IP Logged
If you have "shorted" the injector instead of "opening" the injector it is possible that the injector is firing at all times. This will cause it to run rough at idle, it will be hard to start, and it will run rich. It can also bend rods (excess fuel won't compress and something will have to give) and cause massive engine and catalytic converter problems.
Why would you cut two injectors? I would guess that your motor will still fire with two injectors cut, just with a heck of a miss and little power.
Kevin Pierson
nissanpower
Member - Posts: 8
Posted: November 02, 2013 at 9:06 PM / IP Logged
It's not running excessively rich so I don't think it's shorted or causing the injector to stick open. It's only a very slight hesitation, a slight roughness that I could pick out. The car still starts as normal and drives ok.
I also have another 3rd point of immobilisation in the ignition system so car definitely won't start.
I thought it was a good idea to do the injectors as it wasn't your typical fuel pump/starter circuit that are pretty easy to find and bypass.
KPierson
Posted: November 02, 2013 at 9:50 PM / IP Logged
In reality if it has affected performance you have either open or closed the circuit. There is no way your alarm system would affect the PWM of the fuel injector control circuit. Your immobilizer is most likely a discreet set of contacts on a relay that opens when ignition and ground when armed are both present.
If you feel that your alarm system has caused the problem I would immediately return it to stock and see if the problem goes away.
Kevin Pierson
oldspark
Gold - Posts: 4,913
Posted: November 03, 2013 at 3:58 PM / IP Logged
If you are "disabling" the injector by adding a connection, then you are "shorting" it to GND and keeping it open. No system would do that - it would ruin injectors and bend conrods.
Injector interrupt must be done by breaking the injector connection, else shorting some other sensor.
nissanpower
Member - Posts: 8
Posted: November 03, 2013 at 6:07 PM / IP Logged
the injector signal wire was cut and the immobiliser wires from the alarm were used to intercept it. It was not piggybacked on
oldspark
Gold - Posts: 4,913
Posted: November 03, 2013 at 9:22 PM / IP Logged
Good.
Maybe convert back to standard and see if that makes a difference. Maybe the extra wiring & contacts are increasing resistance and inductance and effecting the pulse or ECU's injector readings.
nissanpower
Member - Posts: 8
Posted: November 04, 2013 at 7:02 AM / IP Logged
Ran a few tests today
- Immobiliser circuit tested okay. Open circuit when armed and continuity between wires when disarmed
- Immobiliser wires no short to ground
- All injectors pulsing when run through alarm (via immo circuit). Tested using screwdriver as a stethoscope
- Back to back tests with immobiliser connected and disconnected. Definitely slight noticeable difference in engine note and exhaust gasses out of the muffler. Sort of sounds like the timing is off
The only other test I can think of is to measure the injector pulse width, this should give me a definite answer.. if only I had the equipment to do so
Until then I've reverted it back to stock so I can have it running nicely.. I'll just have to keep pondering in the mean time
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
