python 413 remote start to 2000 toy rav4.
buddyle2002
Member - Posts: 39
Posted: November 18, 2013 at 11:07 PM / IP Logged
Python 413 remote start to 2000 Toyota Rav4.
Can someone please point me out what i did wrong here, got the remote start with no problem, but no lock or unlock. here are the connections i was using. I tested all the connection are tight and works fine, but for some reason no lock or unlock.
➢ Primary harness (H1) wiring diagram
H1/1 LIGHT GREEN/ BLACK(-) 200mA FACTORY ALARM DISARM---------not used
H1/2 GREEN / WHITE (-) 200mA FACTORY REARM---------------------not used
H1/3 YELLOW (+) 200mA IGNITION OUT (TO ALARM) ---------------not used
H1/4 WHITE/ BLUE (-) 200mA ACTIVATION INPUT ------------------not used
H1/5 ORANGE (-) 500mA GROUND WHEN LOCKED---------------------not used
H1/6 BROWN (-) 200mA HORN OUTPUT-----------------------------used
H1/7 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT----------------not used
H1/8 BLACK GROUND--------------------------------------------used
H1/9 WHITE (+/-) LIGHT FLASH OUTPUT--------------------------used
4-pin satellite harness diagram (no by pass needed)
1 BLUE (-) 200mA STATUS OUTPUT------------------------------not used
2 ORANGE (-) 200mA ACCESSORY OUTPUT-------------------------not used
3 PURPLE (-) 200mA STARTER OUTPUT---------------------------not used
4 PINK (-) 200mA IGNITION OUTPUT----------------------------not used
Heavy gauge relay wiring diagram
1 PINK (+) OUTPUT TO IGNITION CIRCUIT-------------------installed
2 PURPLE (+) OUTPUT TO STARTER CIRCUIT------------------installed
3 ORANGE (+) OUTPUT TO ACCESSORY CIRCUIT----------------installed
4 RED (+) (30A)) HIGH CURRENT 12 INPUT -----------------installed
5 PINK/WHITE (+) PROGRAMMABLE --------------------------installed
6 RED (+) (30A) HIGH CURRENT 12V INPUT12 © -------------installed
Door lock harness, 3-pin connector
1 BLUE (-) UNLOCK OUTPUT-------------installed
2 EMPTY NOT USED
3 GREEN (-) LOCK OUTPUT--------------installed
Remote start harness (H2) wiring diagram
H2/1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT-----------installed
H2/2 VIOLET/WHITE TACHOMETER INPUT WIRE--------------------not used
H2/3 BROWN (+) BRAKE SWITCH SHUTDOWN WIRE------------------installed
H2/4 GRAY (-) HOOD PINSWITCH SHUTDOWN WIRE-----------------not used
H2/5 BLUE/WHITE (-) 200mA 2ND STATUS/REAR DEFOGGER OUTPUT--not used
Very basic installation.    Thank you.
Vehicle wiring:
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
Installation Guide for the python 413:
http://www.12voltdistributors.com/wp-content/uploads/2012/09/Python-413_Installation_Guide.pdf
sparkyssb
Copper - Posts: 205
Posted: November 19, 2013 at 10:52 AM / IP Logged
Looks like that vehicle's lock wire is blue/white (-) and it's unlock wire is blue / YELLOW (-). Both can be found at the "Driver's Kick Blue Connector Negative Trigger or at Lock Module behind Glove Compartment". Are you wired to those? Can you test if those lock/unlock the doors by directly pulsing to ground?
buddyle2002
Member - Posts: 39
Posted: November 19, 2013 at 3:14 PM / IP Logged
I actually hooked to the Driver's Kick.
 lock----blue/white
unlocked----blue / YELLOW.
Wtih the light tester connected to neg and tested each both, unlock lited up and so lock.
thanks for your input.
sparkyssb
Copper - Posts: 205
Posted: November 19, 2013 at 5:47 PM / IP Logged
test the output pins for lock/unlock directly at the R/S unit. Those should show a - pulse when hitting the buttons on the remote.
Also, did you directly test your unlock/lock wires at the driver kick by applying ground to see if your locks actually triggered or not?
