Remote start on a 2003 Diesel chevy
CutDog504
Silver - Posts: 643
Posted: May 16, 2003 at 2:58 PM / IP Logged
I am installing a viper 550 with remote start on a 2003 Chevy Silverdo 2500 3/4 ton 4 door crew cab with a duramax diesel engine. I need help with 3 things. 1: I need a wiring diagram specifically for this 4door deisel truck. 2: I need specific instructions on how to bypass the passlock system, as I have never installed a remote start in which I had to bypass a passlock system. 3: I need any special instrucions on remote starting a deisel engine. I'm thinking (but not positive) that I dont have to worry about anything because with these new durmax diesel engines, you dont have to let the glow plugs warm up. You can get right in and start it up just like a gasoline engine, even if the truck has been sitting overnight.
I've done remote starts on many chevy trucks, but all of them being either a 97 or older. How much more involved willl this 2003 be?? Is the wiring pretty much the same??? If not, please inform me exactly what has changed.   Thanks
CutDog504
Silver - Posts: 643
Posted: May 16, 2003 at 3:13 PM / IP Logged
Also, I've heard that this truck has a databus system (like the trailblazers and envoys) . Will I need any special modules for the keyless entry? I'm installing a viper 550 with remote start, and keyless entry.
CutDog504
Silver - Posts: 643
Posted: May 18, 2003 at 3:27 AM / IP Logged
All the people in here, and not ONE can help me??? Thanks a LOT, YOU GUYS!!!
themagicone
Silver - Posts: 325
Posted: May 18, 2003 at 10:12 AM / IP Logged
First your going to need a bypass kit from bypasskits.com. These trucks have a data bus and without it you will need to relay evrey door. You can also get your passlock bypass from there too. Basicly you just wire it following the instructions included, after you wire it in just start your truck with the key and that all you have to do. Now about the diesel. If you don't need to wait for the glow plugs to warm up your fine. Just find a good tach and wire your tach wire to it.
|              12V|red (x2)            |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink (12 awg)       |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|use Directed module |   |                            |
|     POWER UNLOCK|part #456G *2       |   |                            |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |pass. door module in door   |
| PARKING LIGHTS +|                    |   |                            |
| PARKING LIGHTS -|gray/black          |   |brown plug @ BCM *1         |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|gry/blk(L),blk/wht(R|-  |each door module in door *3 |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|                    |   |                            |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|NOT pnk, blk, or brn|   |any ignition coil           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|pink                |-  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |driver window motor         |
|  RF WINDOW UP/DN|blue - brown        |A  |passenger window motor      |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. The passlock II wire colors are yellow, black, and RED / white (not used).  *1 The BCM (Body Control Module) is under the driver side dash.  *2 If Directed module part #456G is not available, refer to directfax document #1601.  On base model trucks the lock wire is lt. blue (-) and unlock wire is white (-). They are in the lt. blue plug at the BCM.  *3 On base model trucks the door trigger wires are in the lt. blue plug at the BCM. On 4dr trucks the LR door trigger is lt. blue/black, and the RR is lt. GREEN/ black. They are in the purple plug at the BCM. Use all wires and diode isolate.
CutDog504
Silver - Posts: 643
Posted: May 19, 2003 at 10:49 AM / IP Logged
THANKS!!!! One more qwestion. If I have trouble finding a good tach wire, can I just take the tach signal wire and wrap it several coils around a spark plug wire and secure it there with a zip tie? I've used this method once before a while back, but I cant fully remember if the alarm was set up to do it like that.
slugger56
Posted: May 22, 2003 at 1:59 PM / IP Logged
White at cluster
