2013 hyundai elantra remote start
rtl402
Member - Posts: 12
Posted: March 08, 2014 at 4:09 PM / IP Logged
Anyone been able to find the wiring info for a 2013 elantra? It is a basic 4 door model, no chip in the key. Cant seem to find any info here in the shop. Any help would be appreciated. Thanks.
prdjr165
Copper - Posts: 293
Posted: March 08, 2014 at 4:47 PM / IP Logged
12volts
      green (40A)
      ignition switch, white 6 pin plug, pin 1
Starter      yellow      +      ignition switch, white 6 pin plug, pin 3
Second Starter      N/A
Ignition      pink      +      ignition switch, white 6 pin plug, pin 4
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange      +      ignition switch, white 6 pin plug, pin 2
Second Accessory      blue      +      ignition switch, white 6 pin plug, pin 6
Keysense      green to white      -      ignition key switch, white 6 pin plug, pin 4
Power Lock      pink/black      -      dash fuse box, white 24 pin plug (C), pin 19
Power Unlock      yellow/black (all doors); yel/org (driv door only)      -      dash FB, wh 24 pin plg (C), pin 20; dsh FB, rear wh24P plg(G), pin 23
Lock Motor      gray      5 wire      dash fuse box, white 39 pin plug (B), pin 20
Unlock Motor      green or white      5 wire      driver kick, white 56 pin plug, pin 55
Parking Lights+      GREEN/ black (L); BROWN / black (R)      +      dash fuse box, white 39 pin plug (B), pins 9, 10
Parking Lights-      pink      -      headlight switch, white 13 pin plug, pin 2
Hazards      red      -      dash fuse box, rear, white 24 pin plug (G), pin 14
Turn Signal(L)      blue/orange (F); blue/orange (R)      +      dash fuse box, wht 34 pin plug (E), pin 25; wht 39 pin plug (B), pin 7
Turn Signal(R)      RED / orange (F); RED / orange (R)      +      dash fuse box, wht 34 pin plug (E), pin 16; wht 39 pin plug (B), pin 8
Reverse Light      blue      +      driver kick, white 56 pin plug, pin 1
Door Trigger      brown      -      dash fuse box, white 24 pin plug (C), pin 5
Dome Supervision      yellow      -      left front pillar, white 24 pin plug, pin 6 or 5
Trunk/Hatch Pin      green      -      dash fuse box, white 24 pin plug (C), pin 7
Hood Pin      green      -      dash fuse box, white 34 pin plug (E), pin 34
Trunk/Hatch Release      (use trunk release motor)
Power Sliding Door      N/A
Factory Alarm Arm      pink/black (key lock); brn (detect)(Tech Doc 1300)      - and open      dash fuse box, white 24 pin plug (C), pins 23, 6
Factory Alarm Disarm      green (key unlock); brown (detect) (Tech Doc 1300)      both -      dash fuse box, white 24 pin plug (C), pins 16, 6
Disarm No Unlock      (see factory alarm disarm)
Tachometer      green, BROWN / orange, orange, or gray      ac      any fuel injector, black 2 pin plug, pin 1
Wait to start      N/A
Brake Wire      green      +      driver kick, white 56 pin plug, pin 10 or white 16 pin plug, pin 6
Parking Brake      orange      -      dash fuse box, white 24 pin plug (C), pin 22
Horn Trigger      white      -      driver kick, white 55 pin plug, pin 44 or 34
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
MAKE : HYUNDAI | MODEL : ELANTRA | YEAR : 2013
* The logo is registered trade mark of Hyundai Corporate.
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
