datsun 280z parkring light wiring
woodpaper327
Member - Posts: 9
Posted: May 12, 2014 at 7:10 PM / IP Logged
I try to install Viper 350v onto 1975 Datsun 280z.
Following instruction,
http://www.directeddealers.com/manuals/ig/viper/N426V_07-04.pdf
But I can't figure out which wire is "Parking Light"
'75 Datsun 280Z FSM - wiring.
http://www.atlanticz.ca/zclub/techtips/wiringdiagrams/75_280z_wiring.pdf
Does anyone know which wire I should hook up?
Thanks,
tamo3
woodpaper327
Ween
Platinum - Posts: 1,368
Posted: May 12, 2014 at 9:38 PM / IP Logged
green / white
woodpaper327
Member - Posts: 9
Posted: May 25, 2014 at 12:39 AM / IP Logged
Thanks for your advice.
There are lot place I can connect GREEN / WHITE line.
Any recommendation for the best way to connect security system?
datsun 280z parkring light wiring -- posted image.
woodpaper327
Posted: May 25, 2014 at 3:29 AM / IP Logged
The right answer is near to power, ground and starter cuts a real world answer, well hidden with the wires taped over and stealthed.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
