lever nuts for remote starter?
tvmjr76
Posted: June 17, 2014 at 8:11 PM / IP Logged
I am going to install an Avital 4103LX into a 2004 Subaru Outback. I've installed a couple remote starters in the past using the tap splice method, but I've recently discovered these wago lever nuts.
I'm sure they can handle the current. And I think this would be a lot easier/cleaner than the splices... Don't need to solder and tape.
The only thing I don't really like is that I'd have to completely cut the car's wires to use these.
What do you guys think?
Posted: June 17, 2014 at 11:55 PM / IP Logged
No way, unfortunately if you used tap slices and those connectors you'd be immediately dismissed from any decent shop either in the US or UK, absolutely useless in a moving, vibrating damp environment.
racerjames76
Silver - Posts: 581
Posted: June 19, 2014 at 10:32 AM / IP Logged
Totally agree with Howie...Maybe it would work in an old hot rod but in a modern car with sensitive electronics. NO WAY. Added resistance, increased risk of being stranded on the side of the road while your car burns down. It is a personal choice. You won't find support here for doing things the easy way.
I always applaud anyone for thinking outside the box, but in this case the box exists for a reason. lever nuts for remote starter? -- posted image.
Apologies if I sound harsh, but the point needs to get across. lever nuts for remote starter? -- posted image.
To master and control electricity is perfection. *evil laugh*
Posted: June 19, 2014 at 10:37 AM / IP Logged
Even the comment if I was interviewing you:-
"I've installed a couple remote starters in the past using the tap splice method."
Means I wouldn't employ you.
