door lock actuator
hudi
Member - Posts: 11
Posted: July 28, 2014 at 6:27 PM / IP Logged
Does anyone know of a door lock style actuator that when in the locked position, can not be forced open. (not referring to motorized linear actuators, i need it to be controlled by a pulse and do not want someone to be able to "pull up the button" to unlock it)
Thanks,
Hudi
Scorpion
blanx218
Silver - Posts: 654
Posted: July 28, 2014 at 8:11 PM / IP Logged
Never seen an actuator like you're referring to but I have disconnected the rod for the manual "button" so that only the actuator would lock/unlock the door
catback
Silver - Posts: 703
Posted: July 29, 2014 at 1:31 AM / IP Logged
Either BMW or Mercedes had a system like that where-as once locked with the remote it was impossible to open the door from the inside. This poses obvious safety risks and they have redesigned the system.
If the door you don't want anyone to "force" open has a window or key lock those are the prime weaknesses in your theorized setup.
Posted: July 29, 2014 at 4:03 AM / IP Logged
Deadlocks, actuators made by Spal with either 3 or 6 wires (master).
Had a set once. Pulse extra control wire to deadlock.
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
