fiat 500 2014 auto window closer
ofer op
Posted: August 15, 2014 at 4:01 PM / IP Logged
hi,
i installed today on the fiat 500 2014 an alarm unit. - all went good.
i wanted to put an Auto Power Window Closer Rollup Module as well...and i did.
all works fine.....but....
the windows go up only when i close the car threw the original remote controll.
when i press the close botton on the alarm i installed the car is locked - but the windows wont go up.
anyone furmilier with this issue?
thanks,
ofer
Posted: August 16, 2014 at 2:39 AM / IP Logged
What make and model of alarm and what wire are you using to trigger the w/module?
Posted: August 16, 2014 at 3:20 AM / IP Logged
Also have you tried testing?
I assume the window module has a NEG (-) trigger from the alarm?
Have you tried grounding this wire to test?
ofer op
Posted: August 16, 2014 at 8:11 AM / IP Logged
i am using an alarm that you are probably not furmilier of.. its an "ranger" c54 alarm unit.
the window module is a universal "smart 2 window" module.
i am using the (+) turn signal as a trigger for the windows.
the vehicle is a fiat 500 2014, the basic model (leasing car)
i did not connected the window module dirrectly from the alarm, it is opperated as long as the turn signal is working and the acc is off.
Posted: August 16, 2014 at 8:21 AM / IP Logged
That's why it doesn't work from the alarm.
All alarms have a NEG (-) when armed, 1 wire goes to NEG (-) when yo arm the alarm. That wire should be the trigger for your window close, not the other method, then it will work with the alarm.
I always thought Clifford was the brand leader in Israel.
(We have to stick together).
ofer op
Posted: August 16, 2014 at 8:35 AM / IP Logged
i understand what your saying but i am installing everyday 5-8 cars with all kinds of accesories. many times i am installing an alarm + window module but now connecting them together!   every time it works ok - this is the first time i couldnt opperate threw the original remote & the alarm remote.
i thought maybe there is a programming of some kind in the fiat 500.
p.s
if ill connect it as you sayd - it will work threw the alarm remote, but not threw the original remote. (i need it to work with both.)
thanks anyway
Posted: August 16, 2014 at 8:45 AM / IP Logged
Tell you what I'm sick of the UK and the the current political situation, I'll make Olim and come over to teach you!
Did it in the 73 war, maybe I can do it again!
There's away to run off the regular remote, probably using a timer relay, some closers, e.g. DEI product will fire on a latched or momentary output.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
