2014 prius c r start hybrid error
kenca
Member - Posts: 6
Posted: August 31, 2014 at 8:59 PM / IP Logged
I installed a few diy remote starter with fortin evo all with success. This is my first time installing with idatalink blade al bypass module with firstech FT-6200S. I connected all the wires shown on type 10 for prius c 80 bit keys from http://www.idatalink.com/product/product/product_id/4 blade al tl5 installation guide and the blade seems to work properly based on the above guide. When I remote start the car it started and got the "ready" light but I get hybrid error. I bought the cable to reflash the blade module but same problem.
tonanzith
Gold - Posts: 603
Posted: August 31, 2014 at 9:19 PM / IP Logged
Does it light up also during regular start or only on remote start?
Gary Sather
kenca
Member - Posts: 6
Posted: September 01, 2014 at 9:37 AM / IP Logged
only on remote start.
catback
Silver - Posts: 703
Posted: September 01, 2014 at 11:56 AM / IP Logged
You have all (except keysense) the ignition connector wires hooked up (12V, Ign A, Ign B, Acc, Starter)?
Where are you taking power for the FT-6200S from? I wouldn't use the 12V wire at the ignition connector for anything other than powering the remote start harness that feeds the ignition connector.
kenca
Member - Posts: 6
Posted: September 01, 2014 at 9:44 PM / IP Logged
yes 12v, ground, ign, acc, starter, -parking. On the blade I connected the canH, canL, Immobilizer data, ground, doorlock data, and -ground input hook up to ground when running on the FT-6200S. No I didn't connect keysense, the guide said not to connect it. I used the 2 back 12v wires from the ignition to power the two red 12v on the FT-6200S.
catback
Silver - Posts: 703
Posted: September 02, 2014 at 10:09 AM / IP Logged
There are two ignition wires A and B, they both have to be connected. Also recommended place to grab 12v is at the fuse box, the idatalink guide says the given black 12v wire at the ignition connector only supports 7.5 amps.
kenca
Member - Posts: 6
Posted: September 02, 2014 at 8:49 PM / IP Logged
Problem solved thank you. I didn't connect ignition B.
Thursday, October 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
