2004 accord, avital 5303l with pkall
usavpp
Member - Posts: 9
Posted: September 27, 2014 at 11:03 PM / IP Logged
Hi
I am planning to install avital 5303L with PKALL on my 2004 Honda accord. i have a few questions about wiring.
Primary harness (H1), 12-pin connector
H1/6     VIOLET     (+) DOOR TRIGGER INPUT, ZONE 3     not clear where to connect - looks like not required for honda accord since door trigger is -ve ?
H1/8     GREEN     (-) DOOR TRIGGER INPUT, ZONE 3     not clear where to connect - which one of the following ?
Left Front Door Trigger      green
Right Front Door Trigger      lt. GREEN/ red
Left Rear Door Trigger GREEN/ YELLOW
Right Rear Door Trigger      GREEN / WHITE
H1/10     WHITE/ BLUE     (-) REMOTE START ACTIVATION INPUT     Does this goes to Valet program grey wire ?
Heavy gauge relay satellite wiring diagram
H2/2     WHITE/ BLACK     (-) AUX 2 OUTPUT     Where to connect
H2/3     VIOLET/BLACK     (-) AUX 1 OUTPUT     Where to connect
Door lock harness, 3-pin connector
1     LIGHT BLUE     (-) UNLOCK OUTPUT (+) LOCK Where to connect
3     GREEN     (-) LOCK (+) UNLOCK OUTPUT Where to connect
H/8     RED / WHITE     (+) (30A) HIGH CURRENT 12V INPUT Where to connect
Horn, channel 6 (H4), 2-pin connector
H4/1     ORANGE / BLACK     (-) AUX 3 OUTPUT Where to connect
PKALL
6/3     Blue/white     (-) While running (Status)
connection to H3/5 Rear Defogger is this correct?
Appreciate your help and time.
catback
Silver - Posts: 703
Posted: September 28, 2014 at 9:03 AM / IP Logged
H1/6     VIOLET     (+) DOOR TRIGGER INPUT, ZONE 3    NOT USED
H1/8     GREEN     (-) DOOR TRIGGER INPUT, ZONE 3     You have to test and ensure your getting all the doors, it may require connecting to all 4 and using diodes to isolate each
H1/10     WHITE/ BLUE     (-) REMOTE START ACTIVATION INPUT     No it doesn't, this connection isn't required
H2/2     WHITE/ BLACK     (-) AUX 2 OUTPUT     NOT USED
H2/3     VIOLET/BLACK     (-) AUX 1 OUTPUT     NOT USED
1     LIGHT BLUE     (-) UNLOCK OUTPUT (+) LOCK   Connect to vehicle unlock wire
3     GREEN     (-) LOCK (+) UNLOCK OUTPUT        Connect to vehicle lock wire
Power Lock      pink/black (passenger door lock switch)      -      left side of dash fuse box, green 30 pin plug, pin 25
Power Unlock      pink/blue (passenger door lock switch)      -      left side of dash fuse box, green 30 pin plug, pin 9
H/8     RED / WHITE     (+) (30A) HIGH CURRENT 12V INPUT Connect to constant 12v source
12volts white (50A) + ignition switch or dash fuse box, lt. green 6 pin plug, pin 2
H4/1     ORANGE / BLACK     (-) AUX 3 OUTPUT NOT USED
PKALL
connection to H3/5 Rear Defogger is this correct? Yes that will work, the status wire can also be found in the remote start ribbon cable (the blue wire of the ribbon cable) which ends up being accessible at the satellite relay if I'm not mistaken (don't cut the ribbon cable). But to confirm Blue/white will work if you don't need the rear defogger. If you do the blue status runs through the ribbon cable out to the satellite relay which has a connector where you can get the status output.
usavpp
Member - Posts: 9
Posted: September 28, 2014 at 10:24 AM / IP Logged
Thanks catback.
I have followup questions
H1/8     GREEN     (-) DOOR TRIGGER INPUT, ZONE 3     You have to test and ensure your getting all the doors, it may require connecting to all 4 and using diodes to isolate each.
Can you please give more details. if possible specs of diode
Auxiliary harness (H2), 6-pin connector
H2/1     LIGHT BLUE     (-) SECOND UNLOCK OUTPUT Where do i need to connect this.
H/3     RED     (+) HIGH CURRENT 12V INPUT & H/8 RED / WHITE (+) (30A) HIGH CURRENT 12V INPUT can i connect them together to 12V source H/8     RED / WHITE     (+) (30A) HIGH CURRENT 12V INPUT
usavpp
Member - Posts: 9
Posted: September 28, 2014 at 3:13 PM / IP Logged
Hi,
I have one more additional question
H1/11     WHITE     (+)/(-) SELECTABLE LIGHT FLASH OUTPUT
Where do i connect either one or both
Parking Lights(+) RED / black + dash fuse box, white 45 pin plug (N), pin 31
Parking Lights(-) RED / black - headlight switch in steering column cover
Thank you for your time and help
catback
Silver - Posts: 703
Posted: September 28, 2014 at 6:49 PM / IP Logged
**** You have to test the given wires and see if any of them cover all or more than one of the doors otherwise you will need to use all 4. The door trigger wires will test as ground with the door open. As far as diodes to isolate check this page https://www.the12volt.com/diodes/diodes.asp
**** ONLY USED WITH DRIVER PRIORITY UNLOCK - connects to the vehicles unlock wire when driver priority unlock is in use, the light blue unlock wire is then wired to a relay that 5-wired to the drivers door unlock wire.
**** Yes
**** Pick one and set the parking light flash polarity to match on the avital to match before connecting and powering up the avital.
usavpp
Member - Posts: 9
Posted: September 28, 2014 at 9:43 PM / IP Logged
Thanks catback. I will work on it. keep it posted how it goes.
Appreciate you help.
usavpp
Member - Posts: 9
Posted: October 01, 2014 at 8:55 PM / IP Logged
can i connect to car horn (as shown below) instead of connecting it to speaker given in Avital kit
H4/2 BROWN (-) 200 mA HORN to Relay to Horn Trigger GREEN/ YELLOW -     left of steering column, brown 20 pin plug, pin 18
can i connect to car hood pin (as shown below) instead of connecting it to hood pin given in avital kit
H3/4 GRAY (-) HOOD PINSWITCH INPUT, ZONE 1 Hood Pin yellow/red to GREEN/ black - hood switch, gray 2 pin plug, pin 2 or underhood fuse box
Please advise thanks
catback
Silver - Posts: 703
Posted: October 02, 2014 at 12:59 AM / IP Logged
Yes and if your car has a factory alarm or the pin switch installed yes to that as well. If you want the horn to do the chirps like the siren would you will need set that in the programming.
usavpp
Member - Posts: 9
Posted: October 12, 2014 at 11:08 AM / IP Logged
Hi,
I have missed following wires. I didn't get details in directed electronics installation guide. please let me know connection details
Relay satellite 4-pin connector
1. blue   -200mA status output
2. orange -200mA accessory relay turn on
3. purple -200mA starter relay turn on
4. pink   -200mA Ignition relay turn on
catback
Silver - Posts: 703
Posted: October 12, 2014 at 12:21 PM / IP Logged
D2D installation? Not Used, not needed?
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
