Installing a prestige APS 785
Shawn Carter
Posted: May 20, 2003 at 5:44 PM / IP Logged
I would like all the information anyone out there can give me on installing a aps 785 alarm system into a 95 honda accord. Also if u have pic or wiring diagrams to help please send them.Installing a prestige APS 785 -- posted image.
draasch
Gold - Posts: 2,172
Posted: May 21, 2003 at 4:04 PM / IP Logged
Make:   Honda
Model: Accord
Year:    1994-95
This Database Was Last Updated On:    10/7/02
Index #: 5339
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS(FUSED 50 AMP)
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE/ SILVER (-) GRAY MOLEX TO RT. OF STEERING COLUMN
Trunk Pin Switch ORANGE (-) AT LIGHT
Parking Lamp RED / BLACK (+) ABOVE DRV KICK-20 PIN BLUE CONN PIN 6
Power Lock BLACK/ WHITE 2 PIN PLUG, TAPED TO WIRING
Power Unlock ORANGE HARN. ABOVE FUSE BOX #201
#201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
